ATTENTION: We are currently working an issue with posting. Thank you for your patience while we work on a resolution.
Voice Gateway 3745 FXS dial-peer
dvanzee
Level 2
Level 2
I have 8 fxs ports that are used for faxing via Right fax. It appears that some of these ports don't have dial-peers. My questions is, how would I set this up so that all of the ports are used? Can I do this command on all the ports I need?
dial-peer voice 8517 pots
preference 1
destination-pattern 8517
port 4/0/3
forward-digits 0
Can I use the preference 1 for all the right fax ports? Also do I need a dial-peer for every fxs port?
any info would be great.
thomas.chen
Level 6
Level 6
you can configure dial peer for each ports. preference command provide specific dial peers in the pool with a preference over other dial peers.
http://www.cisco.com/univercd/cc/td/doc/product/access/multicon/3810soft/swcfg/dplan.htm
