04-27-2005 08:22 AM - edited 03-13-2019 08:54 AM
I have following setup,
PBX--VoIP GW-------IPWAN---Callmanager cluster.
VoIP gateway is MGCP . PBX is configured such a way that VoIP trunk is first option and PSTN is the second option for making long distance calls.
If VoIP link fails ( such as Callmanager is down or IPWAN between VoIP GW and CM cluster is down) is there a way VoIP gateway shut down the tie line between VoIP GW and PBX ?? PBX can route the call to PSTN correctly if the controller port is down.
Robert
04-27-2005 09:35 AM
Yes, you can use the Advanced Voice BusyOut feature for this.
Check this link for more details
http://www.cisco.com/en/US/products/sw/iosswrel/ps1834/products_feature_guide09186a00800801f3.html
04-27-2005 10:13 AM
Thanks for the response. Will these Monitor probes generate additional traffic on the WAN ?
