Vonage not working behind Cisco 3620 Router
smebbin
Trying to configure vonage behind Cisco 3620 router. It worked fine behind a D-Link home router but not behind the Cisco 3620. Any ideas?
14 Replies 14
paolo bevilacqua
IOS running on the 3620? You need something recent that supports SIP. I have SIP and SCCP clients behind 12.4T and works fine.
Hope this helps, if so please rate post!
How do I configure SIP properly. I keep getting, "Vonage device cannot connect to the vonage network". Here is my show version output. It does supprt SIP.
"Cisco Internetwork Operating System Software
IOS (tm) 3600 Software (C3620-IK9O3S6-M), Version 12.3(18), RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2006 by cisco Systems, Inc.
Compiled Wed 15-Mar-06 22:18 by dchih
Image text-base: 0x60008B00, data-base: 0x61A1C000
ROM: System Bootstrap, Version 11.1(20)AA2, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
ROM: 3600 Software (C3620-IK9O3S6-M), Version 12.3(18), RELEASE SOFTWARE (fc3)
DEFCON-WAN-ROUTER uptime is 11 hours, 27 minutes
System image file is "flash:c3620-ik9o3s6-mz.123-18.bin"
there is nothing special in Vongaes, I assume you NAT config is OK. Check with "show ip nat translatations" that the translation in created as expected.
Beside that I wouldn't know what to say.
That is the problem. I have the ACL setup to allow that subnt as I do the other subnet (which NATs fine). But when I do a show nat trans I do see ANY translation for the subnet.
Would you post all your configuration that is relevant to nat ?
interface Ethernet0/0
description WAN INTERFACE TO COX ISP
bandwidth 10000
ip address dhcp
ip access-group External in
ip nat outside
ip multicast ttl-threshold 8
ip multicast tagswitch
full-duplex
no keepalive
arp timeout 300
no cdp enable
interface FastEthernet1/0
description DMZ INTERFACE TO LAN USERS AND WIRELESS USERS
bandwidth 100000
ip verify unicast reverse-path
no ip proxy-arp
ip nat inside
ip multicast ttl-threshold 2
speed 100
full-duplex
arp timeout 60
no cdp enable
interface FastEthernet1/1
description VONAGE LINK
bandwidth 100000
ip address 192.168.2.1 255.255.255.0
ip access-group vonage_inbound in
ip access-group vonage_outbound out
no ip proxy-arp
ip nat inside
no ip mroute-cache
speed 100
full-duplex
arp timeout 60
no cdp enable
ip nat log translations syslog
ip nat translation timeout 120
ip nat translation dns-timeout 5
ip nat inside source list 1 interface Ethernet0/0 overload
ip nat inside source static udp 192.168.255.254 161 65.182.16.88 161 extendable
ip nat inside source static udp 192.168.255.254 162 65.182.16.88 161 extendable
ip nat inside source static udp 192.168.1.1 161 65.182.16.88 161 extendable
ip nat inside source static udp 192.168.1.1 162 65.182.16.88 162 extendable
access-list 1 permit 65.182.16.88 log
access-list 1 permit 192.168.0.0 0.0.0.255 log
access-list 1 permit 192.168.1.0 0.0.0.255 log
access-list 1 permit 192.168.2.0 0.0.0.255 log
access-list 1 permit 192.168.3.0 0.0.0.255 log
access-list 1 permit 192.168.4.0 0.0.0.255 log
access-list 1 deny any log
NAT config seems fine. Can you try without the ACL vonage_inbound and vonage_outbound ?
How the vonage ATA gets an addess? Can you ping this address?
ACL was taken off. I cannot ping the address and it is directly connected. However it does show up in the arp tables with a "Sh Arp"
How the vonage ATA gets its address ?
Until you can ping it, I would say no chances to have it working.
I ended up having to create a NAT rule and open up UDP 10000 to keep my Vonage ATA working properly. Just a suggestion. I never had to enable SIP or SCCP through my router, either.
YMMV, though.
So I presume I do a static NAt translation for the UDP 10000. Thanks for clarifying ATA, I had no idea what it was. I will also assume since I use DHCP to get an address on the WAN side, I will need to change this static trand\s everytime I have a new IP on the outside.
Nah, I use DHCP also and keep up a translation like so:
ip nat inside source static udp 192.168.0.10 10000 interface FastEthernet4 10000
That's what I use for my Vonage, works well. Not sure if it's totally needed, though. Like I said, once I popped open UDP port 10000 in my ACL, it stayed connected to Vonage's network. I just have the nat translation there *just in case*.
How are you assigning your Vonage ATA an address, though? DHCP or static?
"How are you assigning your Vonage ATA an address, though? DHCP or static?" <--- what do you mean bythat. I can't remember how I set it up originally. But it was behind a Netgear router. Then that stopped working, so I put it behind the d-link and it didn't work. Thn I put the cisco 3620, before the D-link router and off another fa link put the vonage diretly connectedvia crossover (straight through cable wouldn't get a link). Do I have to specify my WAN IP with vonage. I remeber something about a MAC address before.
If you can't remember how you set up your ATA, then it may just be best to reset it and let it grab a proper DHCP address for its subnet in case you put in a static IP that isn't correct for the subnet it is on now.
And you don't have to specify your WAN IP with Vonage. . .all that should be automatically gotten. And the MAC address is so that the ATA device can be registered on Vonage's network.
