vrf aware dns for sip calls
Djeten
on our SBC, I want to have a sip trunk to our partner. I had configured this over ipv4 and this worked perfect.
Now our partner wants us to do send the calls to the DNS name of their SBC's so they can add and remove SBC's if needed, without having to contact us.
We also have VRF's configured on this SBC so I think there is something misconfigured.
When I do ping vrf vrfname domain-name , the domain-name is resolved.
In the dial-peer, I have configured session target dns:domain-name:5060. In the debug output, I can see that the correct dial-peer is selected, but the call fails. I see no outgoing call legs.
Does anybody now where I have made a mistake?
12 Replies 12
configuration seems ok if I compare it to this guide
VRF with ip is working fine, only when I use DNS, the calls fail.
I also checked this guide: https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/ipaddr_dns/configuration/xe-16-5/dns-xe-16-5-book/vrf-aware_dns.html
If you could share your running configuration, without any sensitive information, we could easier help you with verifying the correctness of it.
Response Signature
see attachment, only relevant config included and ip addresses removed
I think that you should try with a IOS version that is much newer than 16.4 as that is about ancient. As the 1000V is limited to a maximum version it would be advisable to upgrade to an 8000V instead. You can do that by simply upgrading the IOS on the virtual router to an IOS version for a 8000V. That will automatically change the hardware from a 1000V to a 8000V. Version 17.6.4 would be my go to choice as that is proven to be a stable release.
Response Signature
Have you check if the host name gets resolved to an IP with the vrf?
As this works with the IP, I assume it’s not resolving to IP address of the destination.
Response Signature
Djeten
yes, when I do ping vrf vrfname domain-name I see the correct ip address
I have read that SRV is not used when you configure the port number like this:
when I add the domain server globally, it works, but I would like to be able to give different DNS servers to different vrf's
Do you need source interface
ip domain lookup vrf ShurgardNixxisSbcVRF source-interface GigabitEthernet2.3691
on ip domain lookup command ?
Response Signature
I have tried with and without source-interface... same result
