05-30-2016 11:51 PM - edited 03-13-2019 09:29 PM
hi,
can any one please help me with dimension details of Wall mount kit of MX800 dual camera single screen & MX300 G2 with 55inch screen.
05-31-2016 02:14 AM
Hi Ankush,
You can find the install related docs for MX series here
http://www.cisco.com/c/en/us/support/collaboration-endpoints/telepresence-mx-series/products-installation-guides-list.html
Manish
05-31-2016 02:26 AM
HI Manish ,
Thanks for the reply ...
I already went through Installation guide for the dimension details part of the WMK but in that only mention unit dimension details .
Ankush
07-14-2016 07:03 PM
The dimensions are indicated on the CAD drawings: mx300g2-cad-drawings.pdf and mx800-cad-drawings.pdf.
ie, for the MX300 G2, see the diagram on Page 3, you can see the bracket in the upper right. It's 9" x 19.9" (229mm x 507mm)
Note: Your question would be better placed in the TelePresence section of the forums where these devices are more actively discussed than in the Other Collaboration section you've posted in - I'd suggest, if the above hasn't answered your query, that you move your discussion over there (you can do this by editing your original post).
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Please remember to mark helpful responses and to set your question as answered if appropriate.
