Will CCM 4.0 install on MCS-7825-1133-HW
rhugo
Level 3
Level 3
I have a customer that has a legacy DL 320 1133 and I want to know difinitively, does this hardware support a CCM 4.0 install and, if so, can someone send me a link to a hardware matrix for new and existing MCS servers and the corresponding CCM software versions that are supported. The Compatibility Matrix doesn't give specifics as to the MCS server hardware itself? PLEASE HELP?
Rob
Chris Deren
It is supported, check out
http://www.cisco.com/en/US/products/hw/voiceapp/ps378/prod_brochure09186a0080107d79.html
There is a part number for DL320 1133 for CCM 4.1, so 4.0 is supported as well.
Hope this helps.
Chris
JeffG1
Level 3
Level 3
Be sure to upgrade the memory on the publisher to 2 GIG of ram... It will need it...
thisisshanky
Level 11
Level 11
Definitely you need a memory upgrade. Trust me, I have one in lab which runs on a P3 800 Mhz (one of the oldest DL320s.) and it has 1 gig or RAM though..I hit CPU cycles of 100 % every 5-10 seconds..even though the server runs great (because I have only 5 phones attached to it).
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
