ASR9K support for Q-in-VNI
Hi all,
ASR9K is supporting VxLAN with MP-BGP/EVPN, it it not very clear to me if it supports Q-in-VNI and if yes, what would be the features and limitations here ?
The docs on the website are not very clear about the subject ..
Rick1776
Level 5
Level 5
What exactly are you trying to achieve?
Rick1776
Level 5
Level 5
I would bet that it isn’t. Looking at the configuration guides for the ASR with VxLAN doesn’t even show that as an option. I do see it supported on the Nexus 9Ks though.
Might need someone from Cisco to chime in on this one....
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/cether/configuration/xe-16/ce-xe-16-book/ce-vxlan-support.html#con_1056474
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/sw/7-x/vxlan/configuration/guide/b_Cisco_Nexus_9000_Series_NX-OS_VXLAN_Configuration_Guide_7x/b_Cisco_Nexus_9000_Series_NX-OS_VXLAN_Configuration_Guide_7x_chapter_011.html?bookSearch...
