07-19-2013 05:47 PM
I have a number of C420 M3's that have no local storage except for the 16GB SD card in slot 1.
The other storage in it is fusion io (for a VDI implementation) cards which wouldn't be seen or desired to install esxi onto.
I have joined them to UCSM since I see on 2.1(2a) the HV boot partition can be enabled from a local disk config policy by a simple tick now.
However no matter what combination of local disk config and boot policy config try I just never gets seen.
Is this a b series only option? Or do I have to do anything to them as standalone servers first to make it be seen?
The c series version came with pretty much the latest version of bios on 1.5 something.
Anyone any ideas?
Solved! Go to Solution.
08-01-2013 11:32 PM
Hello Liam,
The FlexFlash SD card partitions can not be enabled when the C-Series is integrated into UCSM because there is currently not a mechanism for managing the SD card like there is in CIMC.
It is planned for next major release of UCSM
Until then, pleas try the following as a work around.
Enable the HV partition in standalone mode of CIMC and then integrate with UCSM. Then change the BIOS boot order ( press F2 to enter BIOS menu ) to boot from HV partition
Padma
08-01-2013 11:32 PM
Hello Liam,
Padma
