02-21-2011 01:27 AM - edited 03-01-2019 06:54 AM
Hello
I have a topology with two NX5k configured with VPC. I run the 5.0(2)N2(1) software.
In my configuration I filter the vlans that are running on the VPC port-channels. Right now I am trying to add a new vlan to the VPC with the confg-sync feature.
The problem is that the verification process returns me the error "mutual-exclusion checks".
Does anybody know if it is possible to add a vlan to the port-channel with the config sync feature ?
Thank you in advance for any answer.
Lukas
Solved! Go to Solution.
02-22-2011 09:17 AM
You get this message when you have a configuration under your running-configuration (show run) already and you try to add this in conf sync mode.
You can add a vlan with config sync in the port-channel, however the port-channel needs to have been created in config sync or imported from your configuration.
Here is the config-sync operation guide:
http://www.cisco.com/en/US/docs/switches/datacenter/nexus5000/sw/operations/n5k_config_sync_ops.html
02-22-2011 09:17 AM
03-08-2011 06:24 AM
Hello
Thank you very much. It really helped
03-08-2011 11:15 AM
Also remember to use the following commands to check for the config-sync commands used:
“show run switch-profile xxx”
“show run include-switch-profile”
