09-05-2020 04:15 PM
Hi DC Experts,
We have 2 small scale DCs deployed in 2 geographically separate sites. Hyperconverged Vmware clusters in both sites. The full scenario is:
So my question really is whats the most simple and effective way to get both sites talking over an L3 PTP from service provider? Is a type of VPN required over the link, maybe per security? If yes what type? I don't have VXLANs, OTV configured and don't know much about them but can read up on them if required. Just in need of expert help please!
09-05-2020 04:41 PM
First option i can think of only OTV here since the provider giving Laye3 link here :
ISR also can be used to deploy OTV - worked on higher models - ISR2911 - is end of Life ( so Look for ASR or ISR new model, which has feature support of OTV).
09-05-2020 07:26 PM
Ok thanks a lot.
But any other options one may consider? Someone mentioned L2tpvpn? Not so familiar with that but willing to learn, just need the most simple and straight forward solution. Also, stuck with ISR2911 for now, though it should be changed in a few months.
