Factory reset on Hyperflex systems
douglasdickey11
Are there CLI commands to do a factory reset of a new Hyperflex system?
21 Replies 21
Hi Clifford
I See so it need to take a TAC Case to request.
Not having the license shouldn't prevent you from continuing your POC, since a 60-day evaluation period is set when you install ESXi
This resets every time you reinstall ESXi
Hi Clifford
I get a new problem.
When I finish all installation,
and Login to vsphere web Client, It show internal error -
Unable to load resource module form /vshpere-client/pluginui/locales/SrorvisorUi-zh_TW.swf
Is it mean(trandition chinese) not support?
stanleychou,
Can you start a new thread to address this error message?
Hi Clifford
OK
Hi Clifford
If I want to rebuild it to version 1.8.1, is it use different way to rebuild?
I think the 1.8.1 use esxi 6.0 U2 version.
maybe customer want it.
Thank you
jkilleda
Level 3
Level 3
Hello Douglas,
  1. Power down and Delete all Virtual Machines
  2. Unmount Hyperflex datastores from Springpath Plugin > Manage Tab > Datastores > Unmount datastore
3. Delete Springpath datastores from Springpath Plugin > Manage Tab > Datastores > Delete datastore
4.Delete the HyperFlex Cluster in VMware
5.Restart vpxd in Vcenter
--> Linux – login to VC and issue a service vsphere-client restart
-->Windows – go to services panel and start/stop web client
 The Installer VM is designed to handle factory installed systems or if a customer manually re-installs ESXI.  Once you re-install ESXI, simply run the installer as you would normally and it will take care of the rest.
