02-14-2013 07:45 AM - edited 03-01-2019 07:15 AM
I recently installed two Nexus 7009's connected via VPC Peer link to each other. I then connected tow Nexus 5596's to the 7k via double sided VPC. I also had the 5596's joing the VTP domain located on the 7ks. I can not ping outside of a VRF from devices connected on the 5k's I have 3 vrfs created on the 7ks INSIDEVRF, TESTVRF, DATAVRF. The device is currently on a vlan that belongs to the DATAVRF. I can ping any device that is located on the DATAVRF but can not ping or connect to any other VRF. Any assitance with this would be greatly appreciated
02-14-2013 08:12 AM
i forgot the servers that Im trying to ping to are connected to Nexus 2ks that are connected to the 7k
02-14-2013 08:57 PM
What modules do you have in the 7k?
02-15-2013 06:18 AM
1 0 Supervisor module-2 N7K-SUP2 active *
3 24 10 Gbps Ethernet Module N7K-M224XP-23L ok
4 24 10 Gbps Ethernet Module N7K-M224XP-23L ok
Xbar Ports Module-Type Model Status
1 0 Fabric Module 2 N7K-C7009-FAB-2 ok
2 0 Fabric Module 2 N7K-C7009-FAB-2 ok
3 0 Fabric Module 2 N7K-C7009-FAB-2 ok
4 0 Fabric Module 2 N7K-C7009-FAB-2 ok
5 0 Fabric Module 2 N7K-C7009-FAB-2 ok
02-21-2013 11:20 AM
Hi Rob,
From the Nexus 7k can you ping hosts in different vrf when sourcing from DATAVRF? if No then you should see if you are leaking routes between vrfs correctly or not?
JayaKrishna
