N5548P with NX-OS 5.0(3)N2(1) wont work with 2248TP and 2232PP with pre-installed Fabric Extender OS
We recently bought 2 N5K and 4 N2K Fabric extenders, now we are having problem installing the fabric extenders as the FEX just wont go up.
switch(config-fex)# sh fex 100 detail
FEX: 100 Description: ADM/128-SVF-NS302   state: Offline
  FEX version: 4.2(1)N1(1) [Switch version: 5.0(3)N2(1)]
  FEX Interim version: 4.2(1)N1(0.002)
  Switch Interim version: 5.0(3)N2(1)
  Module Sw Gen: 21  [Switch Sw Gen: 21]
  post level: complete
pinning-mode: static    Max-links: 1
  Fabric port for control traffic:
  Fabric interface state:
    Po3 - Interface Down. State: Configured
    Eth1/7 - Interface Down. State: Configured
    Eth1/8 - Interface Down. State: Configured
    Eth1/9 - Interface Down. State: Configured
    Eth1/10 - Interface Down. State: Configured
  Fex Port        State  Fabric Port
Logs:
11/22/2011 07:49:23.536463: Offlining Module
11/22/2011 07:49:23.564858: Deleting route to FEX
11/22/2011 07:49:23.572372: Module disconnected
11/22/2011 07:49:23.573795: Offlining Module
11/22/2011 07:50:34.741573: Module register received
11/22/2011 07:50:34.742363: Image Version Mismatch
11/22/2011 07:50:34.742496: Registration response sent
11/22/2011 07:50:34.742741: Requesting satellite to download image
11/22/2011 07:52:55.922414: Image preload failed.
11/22/2011 07:52:57.91269: Deleting route to FEX
11/22/2011 07:52:57.106904: Module disconnected
11/22/2011 07:52:57.108092: Module Offline
11/22/2011 07:52:57.110203: Deleting route to FEX
11/22/2011 07:52:57.115149: Module disconnected
11/22/2011 07:52:57.116546: Offlining Module
11/22/2011 07:52:57.150559: Deleting route to FEX
11/22/2011 07:52:57.155607: Module disconnected
11/22/2011 07:52:57.156970: Offlining Module
11/22/2011 07:52:57.189131: Deleting route to FEX
11/22/2011 07:52:57.193969: Module disconnected
11/22/2011 07:52:57.195342: Offlining Module
11/22/2011 07:52:57.234153: Deleting route to FEX
11/22/2011 07:52:57.239023: Module disconnected
11/22/2011 07:52:57.240432: Offlining Module
11/22/2011 07:54:40.815191: Module register received
ADM_128-SVF-NS102(config-fex)# sh fex 101 detail
FEX: 101 Description: ADM/128-SVF-NS304   state: Offline
    Po4 - Interface Down. State: Configured
    Eth1/11 - Interface Down. State: Configured
    Eth1/12 - Interface Down. State: Configured
    Eth1/13 - Interface Down. State: Configured
    Eth1/14 - Interface Down. State: Configured
Logs:
11/22/2011 07:49:46.163035: Module disconnected
11/22/2011 07:49:46.164468: Offlining Module
11/22/2011 07:49:46.213737: Deleting route to FEX
11/22/2011 07:49:46.219043: Module disconnected
11/22/2011 07:49:46.220454: Offlining Module
11/22/2011 07:49:46.250091: Deleting route to FEX
11/22/2011 07:49:46.255026: Module disconnected
11/22/2011 07:49:46.256417: Offlining Module
11/22/2011 07:51:09.395617: Module register received
11/22/2011 07:51:09.396381: Image Version Mismatch
11/22/2011 07:51:09.396511: Registration response sent
11/22/2011 07:51:09.396756: Requesting satellite to download image
11/22/2011 07:55:08.409032: Image preload failed.
11/22/2011 07:55:09.671589: Deleting route to FEX
11/22/2011 07:55:09.682174: Module disconnected
11/22/2011 07:55:09.683181: Module Offline
11/22/2011 07:55:09.702525: Deleting route to FEX
11/22/2011 07:55:09.710557: Module disconnected
11/22/2011 07:55:09.711930: Offlining Module
11/22/2011 07:55:09.741583: Deleting route to FEX
11/22/2011 07:55:09.746544: Module disconnected
11/22/2011 07:55:09.747934: Offlining Module
11/22/2011 07:55:09.786138: Deleting route to FEX
11/22/2011 07:55:09.791026: Module disconnected
11/22/2011 07:55:09.792426: Offlining Module
I am seeing "image mismatch" definitely because our N5K is pre-installed with 5.0(3) while fex is using 4.2(1) pre-installed.
Is upgrading the N2K possible? Hope someone can help
Ramon
Jerry Ye
The N5K should upgrade the FEX when it is connected the first time. This pocess can take really long time the first time.
Please post your N5K config.
jerry
8 Replies 8
Jerry Ye
jerry
Hi Jerry,
Thanks for the reply.
Attached is the running-config for one of the N5K connected to 2 Fabric Extender with fex 100 and fex 101.
We have the N5K running for over 24HR and still the fex doesn't come up.
switch# sh int po3 fex-intf
Fabric           FEX
Interface        Interfaces
Po3
switch#
The problem is persistent, the N5K cannot upgrade the N2K's.
Thanks & Regards,
Ramon
Okay, I've reviewed the config and everything looks fine. There in one thing I want you to try before contact TAC:
1. Re-run the install all command -
install all system bootflash:n5000-uk9.5.0.3.N2.1.bin kickstart bootflash:n5000-uk9-kickstart.5.0.3.N2.1.bin
If you want, you can use the latest 5.0.3.N2.2 instead, this should reload the N5K and re-initiate the download process to the FEX. Also, I don't believe this is a cabling issue since both FEXs have the same behavior. If you want, you can try to swap cable to see if it improves or not.
jerry
Dear Jerry,
I tried to do install all command using the pre-installed NX-OS and it is still having the same issues.
I also tried using the latest OS and still no difference.
switch# sh fex 100 detail
FEX: 100 Description: YYYYYYY   state: Image Download
  FEX version: 4.2(1)N1(1) [Switch version: 5.0(3)N2(2a)]
  Switch Interim version: 5.0(3)N2(2a)
  Fabric port for control traffic: Eth1/7
    Po3 - Interface Up. State: Active
    Eth1/7 - Interface Up. State: Active
    Eth1/8 - Interface Up. State: Fabric Up
    Eth1/9 - Interface Up. State: Active
Logs:
11/23/2011 05:20:10.730999: Offlining Module
11/23/2011 05:21:23.942247: Module register received
11/23/2011 05:21:23.943004: Image Version Mismatch
11/23/2011 05:21:23.943130: Registration response sent
11/23/2011 05:21:23.943369: Requesting satellite to download image
11/23/2011 05:22:57.888743: Image preload failed.
11/23/2011 05:22:59.57922: Deleting route to FEX
11/23/2011 05:22:59.63714: Module disconnected
11/23/2011 05:22:59.64937: Module Offline
11/23/2011 05:22:59.84847: Deleting route to FEX
11/23/2011 05:22:59.89833: Module disconnected
11/23/2011 05:22:59.91197: Offlining Module
11/23/2011 05:22:59.134433: Deleting route to FEX
11/23/2011 05:22:59.139335: Module disconnected
11/23/2011 05:22:59.140721: Offlining Module
11/23/2011 05:24:43.341442: Module register received
11/23/2011 05:24:43.342252: Image Version Mismatch
11/23/2011 05:24:43.342384: Registration response sent
11/23/2011 05:24:43.342632: Requesting satellite to download image
11/23/2011 05:26:25.110749: Image preload failed.
I guess I will contact TAC for this, too bad there is no work around.
Ramon
Hi All,
I am still having the problem with the N5K and N2K. While waiting for TAC, I want to try to connect the N2K to our N7K distribution switch to ugrade the Fex OS to 5.x
My question is if I connect the N2K to the N7K with version 5.1(3) will it have a problem if we connect it back to N5K with version 5.0(3) or will it be able to downgrade so we can use it in the N5K.
Really appreciate if someone can confirm if this workaround will work.
Ramon
Hi All,
Using the N7K to install the Nexus 2000 yielded the same result as connecting to our N5K.
switch(config-if)# sh fex 101 detail
FEX: 101 Description: FEX0101   state: Image Download
  FEX version: 4.2(1)N1(1) [Switch version: 5.1(3)]
  Switch Interim version: 5.1(3)
  Fabric port for control traffic: Eth1/11
    Po101 - Interface Up. State: Active
    Eth1/11 - Interface Up. State: Active
    Eth1/13 - Interface Up. State: Fabric Up
    Eth1/15 - Interface Down. State: Configured
  Fex Port        State  Fabric Port  Primary Fabric
Logs:
11/28/2011 06:27:09.662264: Requesting satellite to download image
11/28/2011 06:29:15.232681: Image preload failed.
11/28/2011 06:29:16.459514: Deleting route to FEX
11/28/2011 06:29:16.464452: Module disconnected
11/28/2011 06:29:16.465542: Module Offline
11/28/2011 06:29:16.502250: Deleting route to FEX
11/28/2011 06:29:16.507315: Module disconnected
11/28/2011 06:29:16.520566: Offlining Module
11/28/2011 06:30:27.820404: Module register received
11/28/2011 06:30:27.821854: Image Version Mismatch
11/28/2011 06:30:27.822322: Registration response sent
11/28/2011 06:30:27.822512: Requesting satellite to download image
11/28/2011 06:33:01.789172: Image preload failed.
11/28/2011 06:33:03.21324: Deleting route to FEX
11/28/2011 06:33:03.26651: Module disconnected
11/28/2011 06:33:03.27635: Module Offline
11/28/2011 06:33:03.60441: Deleting route to FEX
11/28/2011 06:33:03.64871: Module disconnected
11/28/2011 06:33:03.68626: Offlining Module
11/28/2011 06:34:14.640167: Module register received
11/28/2011 06:34:14.640895: Image Version Mismatch
11/28/2011 06:34:14.641367: Registration response sent
11/28/2011 06:34:14.641546: Requesting satellite to download image
11/28/2011 06:37:33.144396: Image preload failed.
11/28/2011 06:37:34.373433: Deleting route to FEX
11/28/2011 06:37:34.378391: Module disconnected
11/28/2011 06:37:34.379795: Module Offline
11/28/2011 06:37:34.429214: Deleting route to FEX
11/28/2011 06:37:34.433627: Module disconnected
11/28/2011 06:37:34.436989: Offlining Module
11/28/2011 06:38:45.746477: Module register received
11/28/2011 06:38:45.747175: Image Version Mismatch
11/28/2011 06:38:45.747841: Registration response sent
11/28/2011 06:38:45.748041: Requesting satellite to download image
11/28/2011 06:41:57.68356: Deleting route to FEX
11/28/2011 06:41:57.80615: Module disconnected
11/28/2011 06:41:57.83824: Module Offline
11/28/2011 06:41:57.98377: Deleting route to FEX
11/28/2011 06:41:57.102731: Module disconnected
11/28/2011 06:41:57.106928: Offlining Module
11/28/2011 06:41:57.151366: Deleting route to FEX
11/28/2011 06:41:57.155672: Module disconnected
11/28/2011 06:41:57.158411: Offlining Module
11/28/2011 06:43:08.457500: Module register received
11/28/2011 06:43:08.458280: Image Version Mismatch
11/28/2011 06:43:08.458874: Registration response sent
11/28/2011 06:43:08.459069: Requesting satellite to download image
11/28/2011 06:47:41.719070: Image preload failed.
11/28/2011 06:47:42.949044: Deleting route to FEX
11/28/2011 06:47:42.954394: Module disconnected
11/28/2011 06:47:42.955658: Module Offline
11/28/2011 06:47:42.973122: Deleting route to FEX
11/28/2011 06:47:42.978185: Module disconnected
11/28/2011 06:47:42.981593: Offlining Module
11/28/2011 06:47:43.26743: Deleting route to FEX
11/28/2011 06:47:43.31820: Module disconnected
11/28/2011 06:47:43.35748: Offlining Module
11/28/2011 06:48:48.755085: Deleting route to FEX
11/28/2011 06:48:48.760546: Module disconnected
11/28/2011 06:48:48.764950: Offlining Module
11/28/2011 06:48:54.260037: Module register received
11/28/2011 06:48:54.260794: Image Version Mismatch
11/28/2011 06:48:54.261268: Registration response sent
11/28/2011 06:48:54.261452: Requesting satellite to download image
switch(config-if)# 2011 Nov 28 06:51:43 switch %FEX-2-NOHMS_ENV_FEX_OFFLINE: FEX-101 Off-line (Serial Number XXXXXXXXXXXX)
It's very frustrating.
Ramon
Hi All,
We have resolved the issue regarding the above problem. We found out that the structured cabling was using SMF pigtails on the FO patch panels. That is why we are have the flap error disabled.
We ended up removing the N5K and N2K and connect them with MMF patch cords. Now the N2K is working with the FEX.
Thanks for the support here really appreciated.
Ramon
Hi All,
We had the same problem, replacing the cable and jack in and jack out of the Module solved the issue.
Ranjit
