01-08-2017 11:58 PM - edited 03-01-2019 08:27 AM
Hi.
Are there restrictions and issues when F3 card is mixed with M2 cards?
I assume there's no more issue of L3 Proxy mode with F3 cards.
Please advise.
thanks
01-09-2017 10:01 PM
You can have VDC for either F3/M2 or F3/F2/F2e . You will be limited to the lowest common denominator features.
Manish
- Do rate helpful posts -
01-09-2017 11:04 PM
What about issues on L3 proxy using M cards?
Does F3 has this limitation similar to F2e?
01-10-2017 11:12 PM
If you drop F3 in the same VDC as M1/M2 and you want to know if the F3 be a L2 only card and reply on the M series of proxy L3 or will be a L3 card in it's own right, in this case it will be an L3 card. M2 will be brought down to the capability of F3.
Manish
