N7K ifindex
edwin.sanjoto
I want to ask about netflow for N7K.
When I use netflow version 9 in N7K to forward traffic to netflow server, the netflow server detects all interfaces in N7K with ifindex.
I can mapping the ifindex interface in netflow server with command "show interface snmp-ifindex" in N7K.
But, If I use netflow version 5 in N7K to forward traffic to netflow server, the netflow server detects all interfaces int N7K with different ifindex format with version 9. So, I can't mapping the ifindex interface in netflow server.
Does anyone know how to map ifindex interface in N7K with netflow version 5?
Thank you so much.
Cisco  Tac recommendations if to use V9 flow instead of V5 flow. Please look into the URL decribes in more details Cisco Nexus 7000 Series Flexible Netflow.
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/sw/5_x/nx-os/system_management/configuration/guide/sm_nx_os_cg/sm_15netflow.html#wp1091076
as mentioned : “The Netflow.InputInterface and Netflow.OutputInterface represent a 16-bit I/O descriptor (IOD) of the interface.”
N7K uses 32 bit ifIndex values. Netflow V5 export only supports 16 bit ifIndexes; therefore, We cannot send all 32 bits. In this case, we do send a 16 bit number; however, you cannot use snmp to get the ifIndex to Interface Name mapping on a 1-1 basis.
Please try the command "show system internal im info global" instead of show interface snmp-ifindex, that should give you better view I believe for the if indexes with V5.
