Nexus 2K with VM environment
y_ananthan
Hi Expert,
Can we directly connect ESX servers to Nexus 2K ? or do we need to connect Nexus 5K ?
Thank you.
-Ananthan
jdewberr
Ananthan,
You can abosolutely connect an ESX/ESXi box to a Nexus2000/FEX.
What version of ESX/ESXi will you be running?
Joe Dewberry
jkilleda
Level 3
Level 3
Hello Yoganathan,
Yes , you can connect ESX servers to Nexus 2K
Rick1776
Level 5
Level 5
Yes, you will just use the parent switch in your case the nexus 5k to do the configurations. You would first have to set up the fex within the N5K then you can configure the ports as normal with switchport mode access etc... The interfaces are typically int eth 101/1/1 or whatever you used for the naming or the fex switch.
