Nexus 5596UP with Cisco fet-10g SFP -> validation failed
Julian Geisler
i'm using cisco fet-10g sfp moduls and all these modules are in validation faild status.
changing the portspeed for example to 1G and back to 10G wont fix it.
anyone any ideas?
_____________________________________________________________________________________
sh int brief
Ethernet      VLAN   Type Mode   Status  Reason                   Speed     Port
Interface        Ch #
Eth1/1        1      eth  access down    SFP validation failed       10G(D) --
sh int status
Port          Name               Status    Vlan      Duplex  Speed   Type
Eth1/1        --                 sfpInvali 1         full    10G     1/10g
# sh interface e1/1 transceiver
Ethernet1/1
    transceiver is present
    type is Fabric Extender Transceiver
    name is CISCO-JDSU
    part number is PLRXPL-VC-S43-CD
    revision is B
    serial number is JUS1518A135
    nominal bitrate is 10300 MBit/sec
    Link length supported for 50/125um fiber is 20 m
    Link length supported for 50/125um fiber is 100 m
    Link length supported for 62.5/125um fiber is 10 m
    cisco id is --
    cisco extended id number is 4
sh interface e1/1
Ethernet1/1 is down (SFP validation failed)
  Hardware: 1000/10000 Ethernet, address: 547f.ee05.e208 (bia 547f.ee05.e208)
  MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec,
  Encapsulation ARPA
  Port mode is access
  auto-duplex, 10 Gb/s, media type is 10G
  Beacon is turned off
  Input flow-control is off, output flow-control is off
  Rate mode is dedicated
  Switchport monitor is off
  EtherType is 0x8100
  Last link flapped never
  Last clearing of "show interface" counters 01:11:57
  30 seconds input rate 2784 bits/sec, 348 bytes/sec, 0 packets/sec
  30 seconds output rate 0 bits/sec, 0 bytes/sec, 0 packets/sec
  Load-Interval #2: 5 minute (300 seconds)
    input rate 2.27 Kbps, 0 pps; output rate 0 bps, 0 pps
  RX
    0 unicast packets  1419 multicast packets  0 broadcast packets
    1419 input packets  1494583 bytes
    0 jumbo packets  0 storm suppression bytes
    1 runts  0 giants  0 CRC  0 no buffer
    1 input error  0 short frame  0 overrun   0 underrun  0 ignored
    0 watchdog  0 bad etype drop  0 bad proto drop  0 if down drop
    0 input with dribble  0 input discard
    0 Rx pause
  TX
    0 unicast packets  0 multicast packets  0 broadcast packets
    0 output packets  0 bytes
    0 jumbo packets
    0 output errors  0 collision  0 deferred  0 late collision
    0 lost carrier  0 no carrier  0 babble
    0 Tx pause
  0 interface resets
HA!
I was looking for
feature fex
interfa eth x/y
switch mode fex-fabric
Cheers!
Joe
jdewberr
Hi Dr. Watson,
Could you reply with the following commands?
show feature | grep enable
show runninter interface ethe 1/1
Joe
an softwareupgrade, feature fex and the interface command switchport mode fex-fabric solved the problem.
HA!
I was looking for
feature fex
interfa eth x/y
Cheers!
Joe
