nexus 5k vpc peer-switch command
mcg-tulsa
I am using 5548 and 5596.
both are running
5.1(3)N1(1a)
According to VPC domain documentation, you want to issue the peer-switch command to ensure that both switches in the VPC domain are STP root
these switches do not have the peer-switch command available.
(config-vpc-domain)# ?
  auto-recovery             VPC settings to enable auto recovery if peer is presumed non-operational
  delay                     Initialization delay
  dual-active               Configuration when peer link is down but peer is alive
  graceful                  Enable graceful features
  ip                        Configure IP features
  ipv6                      Configure IPv6 features
  no                        Negate a command or set its defaults
  peer-config-check-bypass  Ignore type checks on primary, when MCT is down
  peer-gateway              Enable L3 forwarding for packets destined to peer's gateway mac-address
  peer-keepalive            Keepalive/Hello with peer switch
  role                      Role related configuration
  system-mac                Configure system mac address
  system-priority           Configure system priority
  end                       Go to exec mode
  exit                      Exit from command interpreter
  pop                       Pop mode from stack or restore from name
  push                      Push current mode to stack or save it under name
  where                     Shows the cli context you are in
Not too familiar with the upgrade process on the nexus.  Will upgrading the NxOS affect my licensing?
It will not affect your existing licensing.
jerry
