nexus 9k monitor sessions only monitors rx
daniel f.
hello together,
on my nexus 9372 monitor session is set to both but the switch only sends out tx packets instead of both rx and tx
!Command: show running-config monitor
!Time: Fri Jan 18 12:28:48 2019
version 7.0(3)I2(2a)
monitor session 1
  source interface port-channel1 both
  destination interface Ethernet1/38
  no shut
sh monitor session 1
   session 1
type              : local
state             : up
acl-name          : acl-name not specified
source intf       :
    rx            : Po1
    tx            : Po1
    both          : Po1
source VLANs      :
    rx            :
    tx            :
    both          :
filter VLANs      : filter not specified
source fwd drops  :
destination ports : Eth1/38
port-channel1 is up
  RX
    2113 unicast packets  310 multicast packets  0 broadcast packets
    2423 input packets  251758 bytes
  TX
    2423 output packets  250704 bytes
Ethernet1/38 is up
  TX
    2165 unicast packets  318 multicast packets  0 broadcast packets
    2483 output packets  257756 bytes
as you can see on port eth1/38 there should be ~4300 unicast packets. in wireshark i also dont see packets from this switch, only the answers. same behaviour on another nexus 9k. what am i doing wrong
0 Replies 0
