Otv on isr 4451
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
10-11-2017 12:36 PM - edited 03-01-2019 08:38 AM
Hello experts ,
can someone please answer the below queries regarding otv on isr 4451
1.Does it support multiple internal interface?
2.Does it support vlan translation over the otv tunnel
thanks in advance
Harish B
- Labels:
Other Data Center Topics
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-11-2017 10:20 PM
2.Does it support vlan translation over the otv tunnel? Doesn't look that feature is supported according to the configuration document as it is in the ASR series. From what I can see you configure it the same way as in the Nexus switch line.
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/wan_otv/configuration/xe-3s/wan-otv-xe-3s-book/wan-otv-confg.html
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-12-2017 12:15 AM
Thanks for your reply. yes that is where I too got confused. I have tried in in ASR and CSR which works fine but not sure about 4451 and none of the document gives proper direction as well
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-12-2017 07:38 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-23-2017 05:14 PM
Hi there,
I 'm hooking to this discussion, as I am also considering OTV on ISR 4451-X.
I alrealdy have those routeurs, I am only missing the appx licence, but doing researching, I noticed throughtput limitation to 100mb/s according to this datasheet:
This is a no go for me; I need gigabits throughput.
Did you tried it already ? Can you confirm the throughput limitation ?
Vincent
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-24-2017 06:41 PM
Hybrid Cloud Connectivity: LISP, OTV5 (for bandwidth less than 100 Mbps), Virtual Private LAN Services (VPLS), Ethernet over MPLS.
Asked when of my friends at Cisco
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
10-24-2017 07:41 PM
