OTV with CSR1K
dganta
We are trying to use CSR1K to extend the Layer 2 using OTV between 2 private Datacenters, we have deployed evaluation AX license and tried to deploy the OTV solution though the join interface is reachable from the Datacenters we are observing that the OTV is not forming adjacency and also though the Internal vlan is extended using bridge domain .
I am getting the following error when I do show otv and also it is not forming OTV adjacency though the Join interface is reachable
balaji.bandi
You need post some config informaton and show output, also worth refer below example :
http://ip-hamsterviel.blogspot.com/2014/08/configuring-overlay-transport.html
BB
DC2:
otv site bridge-domain 150
otv fragmentation join-interface GigabitEthernet2.210
otv site-identifier 0002.0002.0002
otv isis Overlay2
otv isis Site
interface GigabitEthernet3
no ip address
negotiation auto
no mop enabled
no mop sysid
service instance 150 ethernet
encapsulation dot1q 150
bridge-domain 150
service instance 152 ethernet
encapsulation dot1q 152
bridge-domain 152
interface Overlay2
no ip address
otv join-interface GigabitEthernet2.210
otv vpn-name Overlay2
otv use-adjacency-server 10.1.10.181 unicast-only
otv adjacency-server unicast-only
no mop enabled
no mop sysid
bridge-domain 152
On DC-1
>otv site bridge-domain 122
otv fragmentation join-interface GigabitEthernet2.110
otv site-identifier 0001.0001.0001
otv isis Overlay2
otv isis Site
no ip address
negotiation auto
no mop enabled
no mop sysid
service instance 122 ethernet
encapsulation dot1q 122
snmp ifindex persist
bridge-domain 122
bridge-domain 152
interface Overlay2
no ip address
no mop enabled
no mop sysid
bridge-domain 152
on DC1
PD01CSROTV01#show otv
Overlay Interface Overlay2
VPN name : overlay2
VPN ID : 4
State : UP
Fwd-capable : No
Fwd-ready : No
AED-Server : No
Backup AED-Server : No
AED Capable : No, overlay DIS not elected
Join interface(s) : GigabitEthernet2.110
Join IPv4 address : 10.1.10.181
Tunnel interface(s) : Tunnel0
Encapsulation format : GRE/IPv4
Site Bridge-Domain : 122
Capability : Unicast-only
Is Adjacency Server : Yes
Adj Server Configured : Yes
Prim/Sec Adj Svr(s) : 10.1.10.181
On DC2: Same issue
HI,
Also can someone please clarify will the OTV work over SDWAN
