12-05-2012 05:46 PM - edited 03-01-2019 07:13 AM
Hello all,
is there a packet tracer version that has nexus 7k, 5k, FEXs, Fiber Channel switches (MDS 9000 series) load balancers and the rest of R&S boxes?
Thanks in advance,
Solved! Go to Solution.
12-07-2012 03:37 PM
Get ready ...
Catalyst 3850 will soon have WireShark support. Coming to an authorized Cisco reseller January 2013.
PS: NO, it's NOT a type-o.
12-05-2012 06:59 PM
No but you can do packet capture (on the Nexus 7K) so the packet capture file can be read by WireShark.
Don't recall if you can do packet capture on Nexus 5K.
12-05-2012 08:47 PM
leolaohoo,
thanks for your quick response. But the idea was to create several labs since I do not have N7K /N5K or FEXs to tests some configs.
Thanks in advance
12-07-2012 03:37 PM
Get ready ...
