Can not delete the ip igmp join-group command on NX2Ks.
Sergio Gaytan
I have 1 NX5K & 1 NX2K (FEX) and configured PIM on them -Release 5.2(1)N1(1).
I configured on the NX2K's ports the ip igmp join-group command to statically bind a multicast group to an interface. The multicast PIM works fine but when I try to remove the ip igmp join-group command on any interface because not all should have this command, I cannot.
I have not found any  bug on the 5.2(1)N1(1) version related to this behavior and the released notes not mentioned anything about this.
Any ideas...!?
-Sergio
5 Replies 5
Prashanth Krishnappa
Hello Sergio
FEX ports are meant to be L2 ports only and hence you should not be allowed to configure "ip igmp join-group" but looks like we do allow it which is a bug.. I will see if there is one filed for it and if not file a new one.
-Prashanth
Hello Sergio
I have filed a new bug CSCuc58233 for this
-Prashanth
Prashanth,
I have attached the file where you can see that I said (interface Ethernet101/1/1) and I would like to know when I can see the bug details.
-Sergio
Hi Sergio
New bugs take 48-72 hours to be visible on Cisco.com
-Prashanth
Do you know when the information about bug ID CSCuc58233 will be available.
Regards.
~Sergio
