Question about FCOE and IP, in Nexus 5596
Dear Mister
Is possible to do the next. I need to have the two protocols in one 10G interface : FCOE and IP.
The scenary is the next. I have a conection from the FCOE toward FC in Nexus 5596. The servers belong to Blade HP is not using a Virtual Connect. The nexus 5596 is functioning like a "bridge" FC. NPV mode.
This part, the VFC traffic toward the FC interface is functioning.
But I have another part not functioning. Is the IP part.
Is possible to do this? Two protocols (FCOE and IP ) functioning in the same wire? In the next configuration, FCOE is functioning, but IP, the vlan 500 IS NOT working. What is the mistake?
This is the configuracion about FCOE and FC.
slot 1
  port 41-48 type fc
vlan 300
  fcoe vsan 2
vlan 500-549                                        #Vlan about IP
vsan database
  vsan 2
interface Vlan500
  no shutdown
  no ip redirects
  ip address 180.122.228.3/26
  ip router ospf 1 area 0.0.0.40
interface vfc37
  bind interface Ethernet1/18
  no shutdown
vsan database
  vsan 2 interface vfc37
feature npv
npv traffic-map server-interface vfc37 external-interface fc1/41-42
npv auto-load-balance disruptive
interface fc1/41
  no shutdown
interface fc1/42
  no shutdown
  switchport mode trunk
  spanning-tree port type edge trunk
interface fc1/41
  switchport speed 8000
interface fc1/42
FCOE:
show npv flogi -table
SERVER        EXTERNAL
INTERFACE VSAN FCID             PORT NAME               NODE NAME       INTERFACE
vfc37     2    0x010401 10:00:44:1e:a1:5c:7b:41 20:00:44:1e:a1:5c:7b:41 fc1/42
I need help.
Best regard
Prashanth Krishnappa
Unified fabric is all about FC and classical ethernet/IP traffic on the same wire and it should work. When you say IP part is not working. Can you ellaborate?
guijarro_felipe
I am not an expert but you could try to add the VLANs to the eth1/18 with command "switchport trunk allowed ..."
as accoring to the config output not all the vlan are allowed.
rgds
Thank you .
Well, the problem was in the server. The customer configure a tag 500 in the ethernet interface, and the traffic functioned ok.
Best Regarsd
