Well
I have a concern. I understand than by best practices, the PEER-link and the peer-keepalive, should not be in the same link. One best practices is to do the keepalive by the mgmt0, and the peer-link by one Port-channel. That is he normal.
But, what happen when the switch connecting the MGMT0 is down, or turn off? The VPN do not function.
Well, I did the keepalive using another interface. Between the Nexus 5k, not using the MGMT0.
The question is, the problem and risk remain.
The question is: Is possinble in the nexxus 5K to use the MGMT0 and another interface for keepalive purposes???? Like HA keepalive. Is possible that???
Best Regards
