Radius On Nexus 7K
niterid3r
Hi Guys,
When configuring radius on Nexus 7K i get following  error...Which is a bit weird.
radius-server host <IP> key 0 <key> auth-port 1645 acct-port 1646 authentication accounting
aaa group server radius RadServer
    server <IP>
    source-interface lo0
When configuring
aaa authentication login default group RadServer local
Error :
invalid server group could not update aaa configuration
niterid3r.
vsathiam
You configured ( aaa authentication login default group RadServer local )
Try ( aaa authentication login default group RadServer )
From N7k Security Guide -
The local  keyword is not supported (and is not required) when configuring AAA  authentication groups because local authentication is the default if  remote servers are unreachable. For example, if you configure aaa authentication login default group g1, local authentication is tried if you are unable to authenticate using AAA group g1. In contrast, if you configure aaa authentication login default group g1 none, no authentication is performed if you are unable to authenticate using AAA group g1.
Reference:
http://www.cisco.com/en/US/docs/switches/datacenter/sw/6_x/nx-os/security/configuration/guide/b_Cisco_Nexus_7000_NX-OS_Security_Configuration_Guide__Release_6.x_chapter_0100.html#task_1247382
Yep, thats what it was, Thanks!
