Nexus 7000 6.2.2 xcvrInval
csco10387876
Good evening,
after upgrading some 7K from 6.1 to 6.2.2 we encounter the following issue
interface go in xcvrInval state and nothing we do can change it unless changing to a fet or 1G spf.
The same optic in a 6.1 chassi is seen correctly.
xcvrInval is seen on any interface config, from fabricpath to a routed interface.
any advice would be welcome.
Roberto Rodriguez
I would appreciate if you could get some information in regards of this situation.
sh int e x/x transceiver details
Sh run int ex/x
sh version
What type of transceiver is been use in there?
Could you test those trasnceivers on any other port?
Robert Rodriguez
Hello Roberto,
Here are the outpur you asked ;-)
Ethernet1/8
    transceiver is present
    type is 10Gbase-SR
    name is Solid-Optics
    part number is SFP-10G-SR+-SO
    revision is 2.0
    serial number is SO120806478
    nominal bitrate is 10300 MBit/sec
    cisco id is --
    cisco extended id number is 4
    number of lanes 1
           SFP Detail Diagnostics Information (internal calibration)
                Current              Alarms                  Warnings
                Measurement     High        Low         High          Low
  Temperature   28.73 C        90.00 C    -10.00 C     85.00 C       -5.00 C
  Voltage        3.30 V         3.59 V      3.00 V      3.50 V        3.04 V
  Current           N/A        50.00 mA     1.00 mA    40.00 mA       2.00 mA
  Tx Power          N/A        20.99 dBm   10.70 dBm   20.00 dBm     11.69 dBm
  Rx Power      18.21 dBm      20.99 dBm    6.90 dBm   20.00 dBm      7.90 dBm
  Transmit Fault Count = 0
  Note: ++  high-alarm; +  high-warning; --  low-alarm; -  low-warning
interface Ethernet1/8
  description SwDCSmaD02IN
  switchport
  switchport mode fabricpath
  medium p2p
  no shutdown
Cisco Nexus Operating System (NX-OS) Software
TAC support: http://www.cisco.com/tac
Documents: http://www.cisco.com/en/US/products/ps9372/tsd_products_support_series_home.ht
ml
Copyright (c) 2002-2013, Cisco Systems, Inc. All rights reserved.
The copyrights to certain works contained in this software are
owned by other third parties and used and distributed under
license. Certain components of this software are licensed under
the GNU General Public License (GPL) version 2.0 or the GNU
Lesser General Public License (LGPL) Version 2.1. A copy of each
such license is available at
http://www.opensource.org/licenses/gpl-2.0.php and
http://www.opensource.org/licenses/lgpl-2.1.php
Software
  BIOS:      version 2.12.0
  kickstart: version 6.2(2)
  system:    version 6.2(2)
  BIOS compile time:       05/29/2013
  kickstart image file is: bootflash:///n7000-s2-kickstart.6.2.2.bin
  kickstart compile time:  7/9/2013 20:00:00 [08/22/2013 06:51:27]
  system image file is:    bootflash:///n7000-s2-dk9.6.2.2.bin
  system compile time:     7/9/2013 20:00:00 [08/22/2013 10:07:03]
Hardware
  cisco Nexus7000 C7010 (10 Slot) Chassis ("Supervisor Module-2")
  Intel(R) Xeon(R) CPU         with 32745068 kB of memory.
  Processor Board ID JAF1632BFTJ
  Device name: SwDcSmaRIN
  bootflash:    2007040 kB
  slot0:              0 kB (expansion flash)
Kernel uptime is 2 day(s), 18 hour(s), 12 minute(s), 34 second(s)
Last reset
  Reason: Unknown
  System version: 6.1(1)
  Service:
plugin
  Core Plugin, Ethernet Plugin
spf type is 10G spf+ SR from solid optics, we have the same problem with option from other manufacturers, only when using a cisco branded optic does it work.
loss of link or shut of an interface that is currently working (after ISSU from 6.1.1  to 6.2.2) change the state from valid to invalid.
I have a similar problem since the upgrade to 6.2.2.
s_home.html
Software
  kickstart: version 6.2(2a)
  system:    version 6.2(2a)
  kickstart image file is: bootflash:///n7000-s2-kickstart.6.2.2a.bin
  kickstart compile time:  8/23/2013 15:00:00 [10/14/2013 23:54:28]
  system image file is:    bootflash:///n7000-s2-dk9.6.2.2a.bin
  system compile time:     8/23/2013 15:00:00 [10/15/2013 03:58:57]
Hardware
  cisco Nexus7000 C7004 (4 Slot) Chassis ("Supervisor Module-2")
  Intel(R) Xeon(R) CPU         with 12224956 kB of memory.
  slot0:        7989768 kB (expansion flash)
Kernel uptime is 0 day(s), 1 hour(s), 8 minute(s), 14 second(s)
Last reset at 773401 usecs after  Sat Nov 23 14:53:21 2013
  Reason: Reset triggered due to Switchover Request by User
  System version: 6.1(4a)
  Service: SAP(93): Swover due to install
plugin
Ethernet4/25 is down (Transceiver validation failed)
admin state is up, Dedicated Interface
Ethernet4/25
    type is 10Gbase-SR
    name is CISCO-AVAGO
    revision is V03
    serial number is AGD1603405J
    Link length supported for 50/125um OM3 fiber is 300 m
    cisco id is --
    cisco part number is 10-2415-03
    cisco product id is SFP-10G-SR
    cisco vendor id is V03
Hi Gilles,
you need to make sure you have the following command :
"service unsupported-transceiver", I guess you are using 3-party transceivers too.
