04-05-2014 11:14 PM - edited 03-01-2019 07:33 AM
Hi All,
I would like to ask about this feature ..In UCCE system After a time check (if the time is after mid nigh I need to create a script that allow the call to be transferred to an IP Phone (Not Agent) just a number or PSTN number , the most important is "This is not agent".
Solved! Go to Solution.
04-06-2014 11:49 AM
Yes, you can create Dynamic label with the number where you want to transfer and map the same in CVP Static route pointing to CUCM.
Based on Dial-plan CUCM will route the call accordingly.
Siva
04-06-2014 11:49 AM
Siva
04-08-2014 02:51 AM
Hi Siva,
04-25-2014 02:16 PM
Hi - Can you please send me complete CVP and CUCM logs for those calls.
