Unable to bring up link
ghjtruong
                   Hi everyone,
Could anyone could tell me why I can't bring up the link between 7K and 3750 using the following:
7K: 1000base -LH
3750:  1000base-LH
My interface would not come up, I tried to change the speed to the interface on the 7K, it comes back with the error
"ERROR: Ethernet ##, configuration does not match the port capability"
Thank you for the help.
\\Joe
OK..  N7K-M132XP-12 is 10G only card
5 Replies 5
Prashanth Krishnappa
Looks like you have a 10G only capable interface. But you can do show interface ethernetx/y capabilities to check.
Here is an example
20-11-7010-N7k-Core-A# conf
Enter configuration commands, one per line.  End with CNTL/Z.
20-11-7010-N7k-Core-A(config)# int eth1/8
20-11-7010-N7k-Core-A(config-if)# speed 1000
ERROR: Ethernet1/8: Configuration does not match the port capability.
20-11-7010-N7k-Core-A(config-if)# sh int ethernet 1/8 capabilities
Ethernet1/8
  Model:                 N7K-M132XP-12
  Type (SFP capable):    10Gbase-(unknown)
  Speed:                 10000 <<<--------
Here is the snapshot:
NX7K01# sh int ethernet 7/25 capabilities
Ethernet7/25
  Type (SFP capable):    1000base-LH
  Speed:                 10000
  Duplex:                full
  Trunk encap. type:     802.1Q
  FabricPath capable:    no
  Channel:               yes
Guruji... You are every where :)
ghjtruong
Thank you Krishn. Got it.
