06-30-2018 08:25 AM - edited 03-01-2019 08:48 AM
Folks - this may seem like a pretty fundamental question, but the implementation details still escape me. While it is the case that VxLAN offers up to 16 million VNIs in principle, every time I see an implementation of VxLAN, there is a 1:1 mapping with VLANs. In that case, you're not getting more than 4,096 VNIs. So, how does one take advantage of the 16 million VNI capability?
Before seeing these ubiquitous implementations, I always assumed a hierarchical model in which a VNI would map to multiple VLANs - up to 4096. But that is not the case it seems.
01-13-2020 09:58 PM - edited 01-15-2020 01:53 AM
At face value, I get you. Who needs more than 4000 VXLANs? Service Providers do. It's a lot easier to visualize it. This is just a small set of services. In reality, a service provider could have a ton of services on top of just what's in the (crappy) attached diagram. You may not use 16 million, but there are scenarios where the VXLAN may need to be extened to another fabric in the same site if your requirements are great enough to require multiple fabrics connected via super-spines. Note that VLAN1112 is used on multiple switches in the environment. That's because they are locally significant and the tags aren't carried across the fabric. Imagine how tough automation would be if you required the tag to match on both ends...you'd have to have additional logic just to find a matching VLAN assignment on each end.
07-10-2020 02:51 AM
since the vxlan is only add head to the L2 package can i do the following?
08-06-2020 07:00 AM
@yang yang wrote:since the vxlan is only add head to the L2 package can i do the following?
- VNI 5001 - VLAN 20 10.20.1.0/24
- VNI 5001 - VLAN 30 10.30.2.0/24
- VNI 5001 - VLAN 40 10.40.2.0/24
- VNI 5001 - VLAN 50 10.50.2.0/24
From what i understand above, no beacuse the VTEP doesn't encapsulate the VLAN tag in the Vxlan IP packet but :
One one VTEP you'd have : (Because of the 1 to 1 mapping)
On multiple (4) VTEPs you could have :
Or, still across 4 VTEPs :
12-15-2020 04:31 AM - edited 12-15-2020 05:38 AM
Ok so the confusion here I believe is that you are assuming that inside of the same VNI we cannot have more than 1:1 mapping to vlans so therefore only 4000 VNI can be supported.
Note that VXLANs are not necessarily mapped to vlans
there are 2 ways to identify which traffic belongs to which VNI
1- Through subinterfaces (traffic can be untagged or tagged)
2- Through VLAN (traffic must be tagged)
Well, for the second type, the answer is yes inside the same VTEP. But if we go to different VTEP then you can have additional 4000 vlan and additional 4000 VNIs.
And if we distribute the VMs across multiple VTEPs (VNIs) then surely you can have 16M VNIs.
VLAN here is not used in the old way of segregating L2 traffic, it is used by the VTEP to only identify which VNI is connecting to which VM.
VLAN 1 ---> VNI 1 ---> VTEP 1
VLAN 1 ---> VNI 2 ---> VTEP 2
VNI 1 can communicate to VNI 2 through L3 BDIF. And you can have up to 16M VNI.
Only 4K VNIs can exist in one VTEP. But if there is another VTEP, it can have additional VNIs up to the theoretical maximum of 16M.
05-08-2022 03:10 AM
Lets try to do this via an example and lets to scale to 16 million for now I will try to explain how VLAN's are insignificant across a fabric and how VNI's take over the entire fabric and VLAN's are local to a Leaf/Switch
Assume a fabric that has 100 Leafs and each Leaf has 40 VLANs Vlan1 to Vlan40 configured. Hypothetical but good for understanding
Each Switch has the same 40 VLAN's but when an endpoint on Leaf1 with say VLAN tag 1 sends a frame to an Endpoint on Leaf 10 to a system in VLAN 10 the Leaf 1 encapsulates it in a VXLAN header and assigns says VNID 1000. At the Leaf 10 the VXLAN header is stripped off and the original VLAN is now insignificant cause the Leaf 10 now knows where the endpoint is connected on the Leaf and sends the frame out of that Interface
This was basics of VXLAN but was important to drive the concept through. The entire fabric now can use its VNID's irrespective of the local VLAN's configured. To really get to 16 million VNID's you need an insanely large network but you get how even with 4096 VLAN's and a massive network the fabric can use the 24 bit VNID's to scale
Fundamentally VXLAN should never be compared with VLANs. VLANs were a flooding domain whereas VXLAN is a tunneling protocol so the other end does not really bother about the VNID
Hope this helps !!!
05-23-2022 09:44 PM - edited 05-23-2022 09:47 PM
hi,
I am not sure whether this topic is still relevant, what i understand from whole explanation of VXLAN is that VLANs are locally significant to the device, for example you can use 4096 VLANs on one device and in normal trunk network these VLANs are significant across the whole layer 2 domain but with the introduction of VXLAN in the network these VLANs are now just locally significant to switch level only, so if you use 1000 vlans on switch like first 1000 (1-1000) then you don't have to use first (1-1000) on switch to get the information across, you can use 1001 to 2000 on the next switch and communication will still happen if they are part of the same VNI so here your layer 2 broadcast domain is not VLAN its VNI, VLAN has just remained one component which is used on access layer so thats why it is said your broadcast domain is not limited to now 4096 it has enhanced to 16 million (number of VNIs) so in my view the correct statement should be "with VXLAN you can have 16 million broadcast domains rather than 4096"
10-25-2022 04:49 AM
I did not study VxLAN for Cisco, but I did for another vendor. I understand That VxLAN configuration on VTEP is done on two steps, map VLAN to BD and then map BD to VNI. We could consider VNI as customer, tenant, application, department and so on. any of the mentioned tenants could have multiple subnets. So, BD is a subnet and has BDIF, while VNI is an isolation for a group of subnets. VNI seems to me as the concept of VRF. VRF isolates a routing domain or tenant and VN isolates L2.
10-25-2022 09:21 AM
VLAN ID to VXLAN ID mappings enable a great degree of flexibility for network designers that VXLAN-based bridge domain (BD).
VXLAN-based bridge domains can be mapped to single or multiple 802.1Q VLANs as well as to dual IEEE 802.1ad VLAN tags, covering all possible design requirements.
The different available configuration models for VXLAN-based bridge domains are:
Single tag mapping, in which an outer VLAN tag (for example, a customer ID) is mapped to a VNI on an IEEE 802.1ad port and the inner VLAN tags are preserved inside the VXLAN encapsulation. This type of mapping can be used on customer facing ‘QinQ access’ interfaces.
Double tag mapping, in which an outer VLAN + inner VLAN tag pair is mapped to a VNI on an IEEE 802.1ad port (traffic is received double-tagged in ingress and is marked with two tags in egress after VXLAN decapsulation). This type of mapping can be used on multi-VLAN ports (sometimes called QinQ trunks) facing for example an external cloud provider.
Single 802.1Q tag mapping, in which a single 802.1Q VLAN (or multiple 802.1Q VLANs) are mapped to a common VNI (for example, for inter-DC communication within the same customer’s private cloud network).
One VLAN can be associated with only one BD, but one BD can be associated with multiple VLANs.
10-25-2022 01:12 PM
Another response!
Old threads like this really should be locked. If you have a new question or topic, write a new question or write a blog post where we can have a discussion about your (interesting) ideas rather than resurrecting an old thread.
10-25-2022 09:29 AM
https://support.huawei.com/enterprise/en/doc/EDOC1100116686?section=j008
Sorry, for adding a link for another vendor, but I believe they are the same since Cisco is the leader.
10-25-2022 01:08 PM
Hi @Mohamed Gaber ,
I'm not sure what your contribution is really about (on this already ancient thread that should be closed) but I feel I need to sort out some of you misconceptions in case someone actually reads this incredibly boring thread.
Firstly, let's deal with the ORIGINAL question, where @visitor68
@visitor68 If this answers your question, it is a great idea to mark the question as being answered. This helps:
Now to @Mohamed Gaber comments
You are correct that every BD is allocated a VNI and (possibly many different) VLANs. But your description is NOT the way it happens in ACI:
Well, whoever "we" is can consider a VNI as whatever you like. Here is how ACI treats VNIDs
OK - let's unpack that last statement
10-26-2022 03:46 AM
Thanks so much for the details. I started reading about VxLAN shortly for an SDN-Based-VXLAN university campus project. I have several questions and try to find the answer to them. The details of the technology are not clear to me when you come to the low-level design and the configuration level.
10-28-2023 06:31 PM
even i too also have the same doubt ...
