2811 router - Making a beeping noise
ktthilavanh
I have a 2811 making a beeping noise every day for about minute or so. Alarm on router is flashing consistently w/ the beeping when it occurs. No indication in the log or diag. Could this be a problem w/ the fan going out? Any suggestions?
owillins
Level 6
Level 6
Could you paste the show tech and show log and brief description about your toplolgy?
I have 2900 series cisco router. When restart my wifi modem after couple of seconds cisco router start beeping noise.
How should I fix it?
Attach the console cable to the router and start the routers and capture all display logs in a file (boot logs) and share it with us.
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
