2924 switch - Erase command not visible
ek36
I have a 2924 switch (connected via a console port) which is being taken out of service. In enable mode I am unable to use the "erase" command. i.e it is not listed as a command when I do a ?.
I want to erase the config on the switch and return it to the stores. Anyone have any ideas?
Thanks in advance
EK
Prashanth Krishnappa
glen.grant
Just get into the switch in enable mode , type "write erase" and reload the switch , if asks you to save the config say no . Switch will be at factory defaults after reload .
