3745 Router not detecting E1 interface
raju
We have a new 3745 Router with E1 interface . The IOS ver is (C3745-IPBASE-M), Version 12.3(5b) and it has a E1 interface. When I issue a "sh ver" command , it displays as "30 terminal line(s)
1 Channelized (E1 or T1)/PRI port(s) ". When I try to configure E1 interface using controller command , it does not accept the command . What could be the problem?. Does my Router require IOS upgrade , if so , what ver?.
Raju
5 Replies 5
can you post the output of the 'show version' command ? What is the part number of the E1 module that you have installed ?
GP
Hello GP,
Thanks for your response. Just posting the output of sh ver.
RAS-SERVER#sh ver
IOS (tm) 3700 Software (C3745-IPBASE-M), Version 12.3(5b), RELEASE SOFTWARE (fc1
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Thu 15-Jan-04 23:39 by kellythw
Image text-base: 0x60008AF4, data-base: 0x6102E000
ROM: System Bootstrap, Version 12.2(8r)T2, RELEASE SOFTWARE (fc1)
RAS-SERVER uptime is 2 minutes
System returned to ROM by reload
System image file is "flash:c3745-ipbase-mz.123-5b.bin"
cisco 3745 (R7000) processor (revision 2.0) with 184320K/12288K bytes of memory.
Processor board ID JHY0818K1W8
R7000 CPU at 350MHz, Implementation 39, Rev 3.3, 256KB L2, 2048KB L3 Cache
MICA-6DM Firmware: CP ver 2940 - 7/24/2002, SP ver 2940 - 7/24/2002.
Bridging software.
X.25 software, Version 3.0.0.
2 FastEthernet/IEEE 802.3 interface(s)
30 terminal line(s)
DRAM configuration is 64 bits wide with parity disabled.
RAS-SERVER#
Try adding the following global command: -
card type e1 (module mumber) Ie "card type e1 1" if the module is in slot 1
tepatel
No..IOS is fine..I think you have NM-1CTE1-PRI card in 3745. That card can work as T1 or E1 card.
After you insert the NM-xCE1T1-PRI feature network module into the router chassis, you must use the card type command in the command-line interface (CLI) to inform IOS to function NM-xCE1T1-PRI as T1 or E1. The controller will not be configured until you use the card type command. Here is the link which talks more in this issue.
http://www.cisco.com/en/US/products/sw/iosswrel/ps5187/products_feature_guide09186a00801af22a.html#1027188
Following poits to consider.
When the command is used for the first time, the configuration takes effect immediately.
A subsequent change in the card type will not take effect unless you enter the reload command or reboot the router.
Thanks to all. After issuing "card type E1 1 " followed by reload , I can configure the E1 interface using controller command.
Thanks.
