08-24-2006 03:15 AM - edited 03-03-2019 04:40 AM
I installed a redudancy sup720 sup-engine on my 6509. But it is not working properly. How can I make the redudancy engine work properly?
At first I configured redudancy mode like this:
redundancy
mode sso
main-cpu
auto-sync bootvar
I place this engine card in redudancy mode but it start to reboot and reboot again and again. I thought this may be due to the different IOS version.
Then I place this engine card in main mode (unplug the main card) and uploaded the same IOS as the primary one , it shows me log as below:
IOS (tm) s72033_rp Software (s72033_rp-PSV-M), Version 12.2(18)SXD6, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Wed 17-Aug-05 17:34 by evmiller
BOOT = sup-bootflash:,1
BOOTLDR =
Configuration register = 0x2102
Peer (slot: unavailable) information is not available because it is in 'DISABLED' state
CMC-6509-2#
Self extracting the image... [OK]
System Bootstrap, Version 8.4(2) Release
Copyright (c) 1994-2005 by cisco Systems, Inc.
Cat6k-Sup720/SP processor with 524288 Kbytes of main memory
Autoboot executing command: "boot bootflash:"
Invalid device specified
Booting from default device
Initializing ATA monitor library...
string is bootdisk:s72033-ipservices_wan-mz.122-18.SXF4.bin
this shows at first, the redudancy engine wants to boot from bootflash: .But this sup-engine only have sup-disk. So it reboot angain and again.
Also when I type "boot" in rommon mode after i press ctrl+break the redudancy engine start to boot IOS.
Then I use "sh ver" . It shows my log as below:
6509_B#sh ver
6509_B uptime is 13 minutes
Time since 6509_B switched to active is 12 minutes
System returned to ROM by unknown reload cause - suspect boot_data[BOOT_COUNT] 0x0, BOOT_COUNT 0, BOOTDATA 19 (SP by power-on)
System image file is "sup-bootflash:s72033-psv-mz.122-18.SXD6.bin"
08-24-2006 04:37 AM
Looking the following ouput, I see that the Sup720 is trying to boot an hybrid image. Convert it to Native IOS and issue wr mem from the active Supervisor to syncrhonize boot variables.
08-24-2006 06:20 AM
can you explain how to "Convert it to Native IOS " ? Do you mean download a new IOS?
But this IOS is the same one in my active Supervisor .And it works in my active Supervisor .
08-24-2006 06:25 AM
You will need to manually convert it the first time. Schedule a window and follow steps in the following page
http://www.cisco.com/warp/public/473/81.html
You can use a compact flash card and use the Native IOS image on it.
08-24-2006 07:13 AM
Thanks .
Maybe I miss one point: this redudancy can work in correct login mode after i type in "boot" in rommon. And it load the correct IOS and give me a ios login mode than catos mode.
Afeter i read the document you mentioned I wonder shall I convert it again?
