7960G IP phone switchports and BPDU-guard compatibility
tmartin91
The 7960 IP phone has an "internal two-port Ethernet switch allows for a direct connection to a 10/100BASE-T Ethernet network via an RJ-45 interface with single LAN connectivity for both the phone and a co-located PC" per Cisco. Does the fact that this is a switch propagating multiple MAC addresses to my 6509's switchport pose an issue if I'm running BPDU-guard on it ? Don't these "internal switches" on the phones send BPDUs?
Aaron Harrison
It'll work fine - the phones have a 'switch' but don't produce BPDUs or participate in STP.
Aaron
please rate helpful posts
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Aaron Harrison
Aaron
amit-singh
Level 8
Level 8
Hi Friend,
No, the IP phones doesnt send any BPDU's. This will not pose any issues.
HTH, Please rate if it does.
-amit singh
