advertsing point to point links in eigrp
carl_townshend
when I advertise my wan links in eigrp do I just advertise the /30 network on both sides of the wan ?
jheckart
Level 3
Level 3
With EIGRP, when you enter the network command within the routing process, it doesn't advertise what is specified by the command, but rather advertises the interfaces that fall within what is specified by the network command.
Consider the following WAN links
int s0/0
ip addr 192.168.30.5 255.255.255.252
int s0/1
ip addr 192.168.30.9 255.255.255.252
Within the EIGRP routing process, the following command would include both interfaces and advertise both /30 networks
network 192.168.30.0
If you would like to only advertise one of the links, or be more specific, the following would only advertise the network on interface s0/0
network 192.168.30.5 0.0.0.3
Make sense?
