ALIGN-ERR and FCS-ERR
gbrome
Level 4
Level 4
I am getting approximately 150 ALIGN-ERR and FCS-ERR/minute on a Cat 5000 port that connects to a email server with a 100 MB card. The switch port is hard coded to 100 MB, full-duplex.
Is this normal? If not, any ideas where to start fixing this?
Thanks!
t.baranski
Level 4
Level 4
Is the server also hard-coded at 100/full? You have to either hard-code both ends or use auto-negotiation on both ends.
Prashanth Krishnappa
ALIGN-ERR and FCS-ERR are the result of collisions at half-duplex, duplex mismatch, bad hardware (NIC, cable, or port), or a connected device generating frames that do not end with on an octet, and have a bad FCS.
http://www.cisco.com/warp/public/473/53.shtml#datalink
Check for any duplex/speed mismatches, then try swapping out cables, moving to different port
Thanks- I think I found the offending NIC(s)..set to incorrect duplex/speed combinations.
