Applying dialer map causes routing to fail
cmorrall
Scenario is central site 2600 router with e1 pri interface and 6 remote sites with 801 BRI routers.
Remote sites are configured for dial-in central site is configured to accept incomming calls. However when i configure the central site router to make outbound calls with the dialer map statement it causes routing to fail i.e. cannot ping anything even though the connection is made and up - copy of central site config and 1 remote site included below. It appears that when a static dialer map statement is added (exactly the same as the dynamic map created when site dials in except it includes a tel no) it causes the routing to fail.
Can anyone help with this?
CENTRAL SITE CONFIG
version 12.0
service password-encryption
hostname CSD_EPSOM
logging buffered 500000 debugging
aaa new-model
aaa authentication login default local
aaa authentication login console enable
aaa authentication login vty local
aaa authentication login dialin local
aaa authentication ppp default local
aaa authentication ppp dialin if-needed local
enable secret 5 $1$l1AB$uWgZ.leG.eI2UmOx1GmRV/
enable password 7 0820584B080A00
username admin password 7 0005070305480E57
username csd_maple password 7 1218111213180955
username csd_caterham password 7 050A120A205F4B58
username csd_oxted password 7 104F1D1C0404175A
username csd_merstham password 7 130403170A1F017B
username csd_horley password 7 011212015A18035E
username csd_lingfield password 7 094D5A0C18161243
ip subnet-zero
no ip finger
no ip domain-lookup
isdn switch-type primary-net5
call-history-mib retain-timer 500
call-history-mib max-size 500
controller E1 1/0
pri-group timeslots 1-16
interface Ethernet0/0
description Ethernet Link to LAN
ip address 195.106.51.254 255.255.255.0
ip broadcast-address 195.106.51.255
no ip directed-broadcast
no ip mroute-cache
interface Serial1/0:15
description connected to ESPCT Community Sites
no ip address
encapsulation ppp
dialer rotary-group 0
no cdp enable
interface Dialer0
description Dialer Group for ESPCT Comminty Sites
ip unnumbered Ethernet0/0
encapsulation ppp
no ip mroute-cache
dialer in-band
dialer map ip 194.189.4.33 name CSD_OXTED 01883730839
dialer-group 1
no peer default ip address
no cdp enable
ppp authentication chap
ppp multilink
ip default-gateway 195.106.51.1
ip classless
ip route 0.0.0.0 0.0.0.0 195.106.51.1
ip route 194.189.4.0 255.255.255.224 194.189.4.1
ip route 194.189.4.1 255.255.255.255 Dialer0
ip route 194.189.4.32 255.255.255.224 194.189.4.33
ip route 194.189.4.33 255.255.255.255 Dialer0
ip route 194.189.4.64 255.255.255.224 194.189.4.65
ip route 194.189.4.65 255.255.255.255 Dialer0
ip route 194.189.4.96 255.255.255.224 194.189.4.97
ip route 194.189.4.97 255.255.255.255 Dialer0
ip route 194.189.4.128 255.255.255.224 194.189.4.129
ip route 194.189.4.129 255.255.255.255 Dialer0
ip route 194.189.4.160 255.255.255.224 194.189.4.161
ip route 194.189.4.161 255.255.255.255 Dialer0
ip route 194.189.4.192 255.255.255.224 194.189.4.193
ip route 194.189.4.193 255.255.255.255 Dialer0
dialer-list 1 protocol ip permit
snmp-server community public RO
line con 0
login authentication consoleport
transport input none
line aux 0
line vty 0 4
login authentication vty
transport input telnet rlogin
no scheduler allocate
end
REMOTE SITE CONFIG
version 12.1
hostname CSD_CATERHAM
username CSD_EPSOM password atease1
ip subnet-zero
no ip domain-lookup
isdn switch-type basic-net3
interface BRI0
description Link to EPSON
no ip address
encapsulation ppp
dialer pool-member 1
ppp multilink
interface Ethernet0
ip address 192.168.4.1 255.255.255.0
ip nat inside
no cdp enable
interface Dialer0
ip address negotiated
ip nat outside
encapsulation ppp
dialer remote-name CSD_EPSOM
dialer pool 1
dialer string 01372723300
dialer-group 1
no cdp enable
ppp multilink
ip nat inside source list 102 interface Dialer0 overload
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer0
no ip http server
access-list 101 permit ip any any
access-list 102 permit ip 192.168.4.0 0.0.0.255 any
dialer-list 1 protocol ip list 101
line con 0
line aux 0
line vty 0 4
password atease1
login
end
11 Replies 11
tepatel
If the config posted above for 801 is the one in which the central 2600 will dial into, we have mismatch in dialer map statement. You have configured
while the name of the 801 will be CSD_CATERHAM. so if you change that in that dialer map i think it should work.
You will be able to see the problem once we have the following debug on at central router
debug dialer
debug ppp nego
debug isdn q931
debug ppp authentication
Pl. post it here if problem is still there with config change too.
Thanks for your reply.
I know the config for the 801 is not the router that is configured in the central site config I just used it as an example their are 6 of them. The debugs I have tried - as I said the routers connect and authenticate ppp fine it's just that when you add the dialer map statement on the central site router and the remote site dials in it connot ping anything. If I remove the dialer map on the central router the router dialing works fine!
Did you try adding broadcast on to end of the dialer map statement?
The reason I say this is, in your config the remote site has static pointing to dialer0. doing statics this way uses proxy-arp. this means it's going to ARP to find where that is and since central site doesn't allow broadcasts a return ARP isn't going to be sent thus he doesn't know where that is. You can try putting next hop IP address instead of interface as well.
Need to now the reason why you ned to add the static dialer map once the dynamic dialer map is already there. If you need to add the static dialer map, you need to add it before the dialing occurs..
I need to add add the static dialer map on the central site to allow it to bring up the connection and dial the remote site, i.e. 2 way ddr. The dynamic map is created on the central site when the remote site dials in but obviuosly if the central site dials out then the static map needs to be used for the telephone number.
I will try the broadcast command as suggested.
Thanks Guys
You are right..You need to add the dialer map to dialout. So when you add the dialer map and the central site dialout on first channel to remote site, the central site is not able to ping the remote..right?
We need to know what dialer map you are adding along with the debug i have requested earlier. Also the "broadcast" in the dialermap is used for to send the routing updates over the link. So you may not need it if you are not using the routing protocol over the link.
The central site config I included has a dialer map statement for one of the remote sites. I included thia as an example. I will try and get the debug out put over the next few days and post. Do you think this will help being as it's not the connection that fails only routing. i.e. the connection comes up ok - I can see the router dialing in and attaching ok. The brodcast command was suggested by someone else - see earlier mail response. Do you think that the problem may be down to using IP Unnumbered? I must admit I did not try using IP addresses for the dialer profiles.
The debug will help to see any issues with IPCP leyer along with the hostname received from remote side..That hostname is case sensitive so we need to have it exactly matches in dialer map..Mismatch in hostname will make the routing fail..You will see encapsulation faied when you have "debug ip icmp" at the time of ping.
So need to have the debug with the dialermap statement you are using.
This is issue is now resloved after resolving another related issue with outbound dialing on the PRI.
Thanks for the input on this.
Chris Morrall
Not applicable
I have the same problem that you had, could you please till me how did you solve it. thanls a lot
The issue that was two fold. firstly outbound dialing was not working from the central site router - the ISDN switch on the service providers nework was sending a message back saying it was unabel to allocate a channel to make the outbound call. But also when this was happening and the remote sites dialed in - with the dialermap statement on the central site configure the remote sie was unable to ping. When we sorted out the first issue (BT gave us incorrect info on the number of timeslots enabeled initialy) and reapplied the dialer maps it all worked! Unorftunately the client fixed this on their own after we resolved the timeslots issue. But it may have been down to case sensitiviy of the router names - make sure they are the same on the dialer maps, user/password and router!
