12-08-2016 07:01 PM - edited 03-03-2019 08:24 AM
What commands show the status of the fans in an ASR 920-24SZ-IM? The Status Light is red on our router...
12-12-2016 05:15 PM
Hi Julie,
You can run the command:
show environment all
show platform
If the state is not normal/ok i will recommend you to open a TAC case.
Hope this info helps!!
Rate if helps you!!
-JP-
Log in to Community
