ATM/EIGRP Problems
t.zelenik
I am using a 2621XM with an AIM-ATM linecard and a VWIC-MFT-T1 card for an ATM to IMA connection. I have configured the T1 controller for ATM and the linecode and framing are correct. The ATM interface is set correctly for the aal5snap encapsulation. The problem I am having is that EIGRP sees the adjacent router and then times out giving an error message on the IMA router saying that the K value is mismatched. I am not sure what that means or where to look. Please help!
5 Replies 5
ruwhite
Level 7
Level 7
Make certain neither of the two routers have their k values set in the eigrp config. You could post the configs here to verify that...
The second thing is this may not be an actual k value mismatch, but rather EIGRP sending a goodbye message. I thought I had just edited a doc on this, but I can't find it on CCO now.... Essentially, there is a new feature in EIGRP, if a router is shutting down a neighbore relationship for some reason, it will send a "goodbye" message, which is a hello with all the k values set to 255. If the neighbor receiving this hello supports graceful shutdown, it will print out a message about the neighbor going down because of a graceful shutdown. If not, it will print out a k value mismatch message.
Could you check the console log on the other router? Make certain you have log neighbor changes configured on both sides, and see why the other router says the neighbor relationship is failing. If it's sending a goodbye message, the other router should give you more information on why.
Russ.W
Neither router has a K value set out of default.
On the other router, it says that the holdown timer expired. The remote router is running a much newer version of IOS 12.3(6) I believe (I will verify and post later).
Do you think this could be a problem on the ATM settings causing the problem?
I will post more information later, but hopefully this will help.
Tom
Log information on the IMA side:
Jun 3 08:27:28.005 CDT: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 100: Neighbor 192.168.251.6 (ATM2/ima1.9) is up: new adjacency
Jun 3 08:27:41.509 CDT: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 100: Neighbor 192.168.251.6 (ATM2/ima1.9) is down: K-value mismatch
Jun 3 08:27:45.837 CDT: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 100: Neighbor 192.168.251.6 (ATM2/ima1.9) is up: new adjacency
Jun 3 08:27:59.697 CDT: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 100: Neighbor 192.168.251.6 (ATM2/ima1.9) is down: K-value mismatch
Jun 3 08:28:04.301 CDT: %DUAL-5-NBRCHANGE: IP-EIGRP(0) 100: Neighbor 192.168.251.6 (ATM2/ima1.9) is up: new adjacency
EIGRP settings on the IMA side:
router eigrp 2416
redistribute eigrp 100
network 10.16.1.0 0.0.0.255
network 10.230.17.0 0.0.0.255
distribute-list 1 in
no auto-summary
no eigrp log-neighbor-changes
router eigrp 100
redistribute eigrp 2416
network 10.0.0.0
network 192.168.251.0
no auto-summary
access-list 1 permit 172.30.0.0 0.0.255.255
access-list 1 permit 192.168.251.0 0.0.0.255
access-list 1 deny 10.10.0.0 0.0.255.255
access-list 1 deny 10.2.0.0 0.0.255.255
access-list 1 deny 10.3.0.0 0.0.255.255
access-list 1 deny 192.168.0.0 0.0.255.255
access-list 1 remark Above denies conflict networks
access-list 1 permit 10.0.0.0 0.255.255.255
Show Version:
IOS (tm) 7200 Software (C7200-JS-M), Version 12.2(15)T11, RELEASE SOFTWARE (fc2)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Sat 31-Jan-04 11:07 by nmasa
Image text-base: 0x60008954, data-base: 0x61F8E000
ROM: System Bootstrap, Version 12.0(19990210:195103) [12.0XE 105], DEVELOPMENT SOFTWARE
BOOTLDR: 7200 Software (C7200-BOOT-M), Version 12.0(2)XE2, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
Local_Oklahoma uptime is 7 weeks, 17 hours, 45 minutes
System returned to ROM by reload at 07:46:27 CDT Wed Apr 14 2004
System restarted at 14:47:47 CDT Wed Apr 14 2004
System image file is "slot0:c7200-js-mz.122-15.T11.bin"
cisco 7206VXR (NPE300) processor (revision B) with 122880K/40960K bytes of memory.
Processor board ID 16066266
R7000 CPU at 262Mhz, Implementation 39, Rev 1.0, 256KB L2, 2048KB L3 Cache
6 slot VXR midplane, Version 2.0
Last reset from power-on
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
TN3270 Emulation software.
Primary Rate ISDN software, Version 1.1.
1 FastEthernet/IEEE 802.3 interface(s)
10 ATM network interface(s)
12 Channelized T1/PRI port(s)
125K bytes of non-volatile configuration memory.
20480K bytes of Flash PCMCIA card at slot 0 (Sector size 128K).
46976K bytes of ATA PCMCIA card at slot 1 (Sector size 512 bytes).
4096K bytes of Flash internal SIMM (Sector size 256K).
Configuration register is 0x102
This makes sense--one end is dropping the neighbor relationship because of the hold timer expiring, and when it does, it sends a "goodbye" message, which the other router interprets as a mismatched k value problem, dropping the neighbor relationship on that end. It's working as the feature was designed. :-)
I would chase the hold timer expirations at this point--why are we dropping enough eigrp traffic to lose the relationship. I would first look at the interface counters to see what they are saying (do you have a lot of drops?). Does the neighbor relationship ever come up at all?
Russ.W
It ended up being an ATM configuration problem (although I am skeptical). I didn't have the vbr-nrt statement corrct, which was causing drops. I think that I was looking a layer too high!
Thanks for all the help!
Tom
