01-22-2003 01:05 PM - edited 03-02-2019 04:26 AM
running rme 3.4
dfm 1.2
cm 3.2
1) When I view the net. topology it shows a '?' for my 2620's. Also, the 2620 isn't showing up on the right side of the view. It shows 72xx's, 2950's, etc. but no 2620. How do I change that.
2) Some T1 links on network topology are missing. How do I fix that?
3) In Monthly Latency Report, what does it mean that I have 100% error for an MSFC DHCP Request?
4) Under Management Connection->Browse Device. How do I browse if the http port that I've opened is not port 80? Can I change the 'fall-back' port?
5) Why is it bad to export more than 50 devices to visio?
Any help on any question would be GREAT!
Solved! Go to Solution.
01-22-2003 02:16 PM
CiscoProducts.468 is the sysObjectID of 2620XM type of router which is a different chassis type than the regular 2620. It is supported in with Incremental Device Update (IDU) 2.0 installed which you can get from:
http://www.cisco.com/cgi-bin/tablebuild.pl/cw2000-campus
There's also IDU 2.0 for RME 3.4 which you can get from:
http://www.cisco.com/cgi-bin/tablebuild.pl/cw2000-rme providing additional new device support including the above as well.
01-22-2003 01:32 PM
1) Does this 2620 show up on the map with the correct icon?. What is the sysObjectID for this 2620?
2)http://www.cisco.com/en/US/products/sw/cscowork/ps563/products_tech_note09186a0080094949.shtml can be used to narrow down.
5) Haven't seen this. Does CCO Bug Toolkit reveal anything close?
01-22-2003 02:04 PM
It shows an Icon with a 'question mark'. It appears to be listed as 'CiscoProducts.468' instead of as a 2620.
01-22-2003 02:16 PM
