Campus Manager Network Topo. View Problems
aarviola
I'm having problems on my desktop running Win2K. When I display Layer 2 view, all of the icons are stacked. I try to use the View -> Relayout option and it has no effect. This happens whether I use IE or Netscape. I go to another computer and it displays fine. I've reinstalled Java and the web browsers and nothing seems to help.
I realized that the problem resides on my desktop computer, but have no idea what to try next to fix the problem. Thanks for any help.
Tony
rmushtaq
Level 8
Level 8
What is the version of Campus Manager?
Thanks for your reply. The problem occurs with two different servers running two different verions--3.1 and 3.2.
There was a problem similar to what you're seeing but only in Campus 3.1 and on European Locales only which have been fixed in 3.2. Are you on a European Locale?. For 3.2 you may first want to search the CCO Bug Toolkit to see if there are any known issues for this version before contacting TAC.
I located on the U.S. East coast. Thanks for the tip. I'll check for a Bug.
