Can I upgrade IOS versions legally, without a maintenance contract?
jimmyc_2
Some of my devices do not have maintenance, as we use them for spares.   Can I upgrade the IOS without violating the end user agreement?
burleyman
Level 8
Level 8
No. You need a valid support contract on the device.
Mike
5 Replies 5
burleyman
Level 8
Level 8
Mike
Thanks Burleyman.   Not what I wanted to hear, but good information.
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-4500-series-switches/product_bulletin_c25-696974.html
This document explains that software updates can be deployed without a service contract on devices running LAN Lite, LAN Base and IP Base.
jmandersson
Is this Always true?
Sometimes you may see that Cisco offers "free upgrade" in case of security problems, like the Heartbleed bug for example.
Johan
rvarelac
Level 7
Level 7
Hi jimmyc_2 ,
yes , If you have a valid security reason such as hearthbleed , you can open a case with TAC  as one-time exception ,  and we will publish you the required image to patch the issue.
Hope this helps
-Randy-
