Cat6500 conversion from hybrid to native
jeff.vargas
Is there a tool that will covert your existing supervisor configuration to a native IOS configuration?
2 Accepted Solutions
Hello Jeff,
are you looking for this ?
Catalyst OS to Cisco IOS Configuration Converter
http://www.cisco.com/cgi-bin/Support/CatCfgConversion/catcfg_xlat.pl
GP
thisisshanky
Level 11
Level 11
Please be aware that not all configs will convert properly with this tool You might want to understand equivalent commands under each OS before you do the migration.
Check this link.
http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a008010e9d5.shtml
PS: please remember to rate helpful replies!
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
Hello Jeff,
GP
This tool does not seem to be working at least over the last 5 days.
I have tried to upload and convert 8.3 catos config, and also tried cutting and pasting in the conversion box.
Browser status says: Opening page http://...catcfg_xlat.pl..
But conversion never happens, browser just times out.
Anyone else having problems?
Yes, I had the same problem. I finally wrote a perl script to do the port-level configuration because I had a ton of ports. Adjust as you see fit:
open (PORTS,"sw2.txt");
open (NEWSW1,">sw2-new.txt");
@ports = ;
foreach (@ports) {
($port,$desc,$conn,$vlan) = /(\d+\/\d+)\s+(.*)\s+(connected|notconnect)\s+(\d+)\s+/;
if ($conn) {
print NEWSW1
"interface g$port\n desc $desc\n switchport host\n switchport access vlan $vlan\n no shutdown\n";
thisisshanky
Level 11
Level 11
Check this link.
Sankar Nair
