Catalyst WS-C3524-XL-EN interface problem
mhostbaek
I have 3 catalyst C3524XL switches, all running IOS-12.0(5)WC5 - and all having the exact same problem (that I was I doubt it is a hardware problem).
When I plug in a cable into one of the fastethernet ports, the port goes up (and I have assigned an IP to vlan 1) and everything seems good - however when I try to ping something on my LAN - no packets are going through.. (It works on the Gigabit interfaces) but all FastEthernet interfaces sends nada through..
I tried putting on debug all, while pinging to see what's going on - but I cannot find the cause, I hope somebody with more clue than me can point me in the right direction.. thanks..
Snippet from 'debug all' :
00:03:47: ST: Data 0000000000800000D00692A0800000006480010009B79E80C080060100140002000F00
00:03:47: ST: FastEthernet0/17 vlan 1 0000000000800000D00692A0800000006480010009B79E80C080060100140002000F00
00:03:47: ST: Heard root 32768-00d0.0692.XXXX on FastEthernet0/17 vlan 1
00:03:47: CPU Interface 0 storage notify failed on queue 1
00:03:48: IP ARP: sent req src 192.168.3.177 0007.856d.9100,
dst 192.168.3.1 0000.0000.0000 VLAN1
00:03:48: CPU Interface 0 storage notify failed on queue 1
00:03:49: IP ARP throttled out the ARP Request for 192.168.3.1.
00:03:50: CPU Interface 0 storage notify failed on queue 1
00:03:50: IP ARP: sent req src 192.168.3.177 0007.856d.9100,
00:03:50: IP ARP throttled out the ARP Request for 192.168.3.1
00:03:51: IP ARP throttled out the ARP Request for 192.168.3.1
00:03:52: SNMP: HC Timer 693D28 fired
00:03:52: SNMP: HC Timer 693D28 rearmed, delay = 5000
00:03:52: CPU Interface 0 storage notify failed on queue 1
00:03:52: IP ARP: sent req src 192.168.3.177 0007.856d.9100,
00:03:52: CPU Interface 0 storage notify failed on queue 1.
00:03:53: IP ARP throttled out the ARP Request for 192.168.3.1
00:03:54: CPU Interface 0 storage notify failed on queue 1
00:03:54: IP ARP: sent req src 192.168.3.177 0007.856d.9100,
00:03:54: CPU Interface 0 storage notify failed on queue 1.
00:03:55: start_timer id mismatch satellite dm 0 state 1 id 53CB04 exp id 53CAC4
00:03:55: start_timer id mismatch satellite dm 0 state 1 id 53CAC4 exp id 53CA04
00:03:55: start_timer id mismatch satellite dm 0 state 1 id 53D1C4 exp id 53C9C4
00:03:55: start_timer id mismatch satellite dm 0 state 1 id 53D444 exp id 53C904
00:03:55: IP ARP throttled out the ARP Request for 192.168.3.1
00:03:56: CPU Interface 0 storage notify failed on queue 1
00:03:56: IP ARP: sent req src 192.168.3.177 0007.856d.9100,
00:03:56: IP ARP throttled out the ARP Request for 192.168.3.1
00:03:56: SNMP: HC Timer 691C04 fired
00:03:56: SNMP: HC Timer 691C04 rearmed, delay = 20000
00:03:57: SNMP: HC Timer 693D28 fired
00:03:57: SNMP: HC Timer 693D28 rearmed, delay = 5000
00:03:57: IP ARP throttled out the ARP Request for 192.168.3.1
00:03:58: CPU Interface 0 storage notify failed on queue 1
00:03:58: IP ARP: sent req src 192.168.3.177 0007.856d.9100,
dst 192.168.3.1 0000.0000.0000 VLAN1.
Success rate is 0 percent (0/5)
Switch#
Any help would be much appreciated..
/mich
8 Replies 8
gsousa
Hi.
From what i can see maybe the problem isn't on the switch.
You were trying to ping from 192.168.3.177 to 192.168.3.1.
The host 192.168.3.177 made an ARP Request trying to discover 192.168.3.1's MAC Address.
Now the host 192.168.3.1 had to reply to this request, and it didn't.
Sometimes host running load balance protocols (like HP Team, or Microsoft NLB) do that.
Could that be the case?
best regards
No.
The 192.168.3.1 is a cisco 1600 router, that is connected to another catalyst switch (on which this particular switch is also connected) I have also tried pinging the directly connected switch, but same result.
Now what really puzzles me is, that cdp packets are getting through..
Switch#sh cdp n d
Device ID: s2
Entry address(es):
IP address: 192.168.3.157
Platform: cisco WS-C2950G-24-EI, Capabilities: Switch IGMP
Interface: FastEthernet0/17, Port ID (outgoing port): FastEthernet0/6
Holdtime : 133 sec
advertisement version: 2
Protocol Hello: OUI=0x00000C, Protocol ID=0x0112; payload len=27, value=00000000FFFFFFFF010221FF000000000
VTP Management Domain: ''
Duplex: full
Switch#ping 192.168.3.157
Sending 5, 100-byte ICMP Echos to 192.168.3.157, timeout is 2 seconds:
Odd isn't it ?
/mich
It is not so odd since CDP is Layer 2, there are other factors in which it might not pingable on a Layer 3 point of view.
If it is desired to reach it, we need to look at the Layer 3 connectivity.
Corey
Ok - that makes sense.
Is there some special debug commands, I could type in that would give you some valuable output ?
I tried:
'debug ip icmp' - but nothing shows, when I try to ping a host..
/mich
could be a negotiation problem between the switch and 1601 router?
Try to force both interfaces (router and switch) to 10Mbps / half-duplex.
best regards
I just tried that, and it had no effect !
/mich
You've probably already checked, but check your subnet mask and VLAN settings for the fast ethernet ports on both sides.
Is the connected port on the management VLAN?
Maybe you could cut and paste some configurations, since it is unlikely to be a hardware problem, it is either s/w bug in the code, or configuration issue...
The connected switch obviously work, and is connected to plenty of other devices... the "faulty" swtich, has the following conf:
Current configuration:
version 12.0
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname Switch
ip subnet-zero
no ip domain-lookup
interface FastEthernet0/1
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface VLAN1
ip address 192.168.3.177 255.255.255.0
no ip directed-broadcast
no ip route-cache
line con 0
transport input none
stopbits 1
line vty 0 4
login
line vty 5 15
login
end
Switch#
And yes the other end is on the 192.168.3.0/24 network..
/mich
