CISCO 1760 - ISDN Dialer Idle-Timeout
dean.pecorari
I have configured an isdn dialer to stay up for 7200 seconds however it timeouts aftet the default period of 120 secs.
I am using IOS (tm) C1700 Software (C1700-ADVSECURITYK9-M), Version 12.3(5a) on a 1760 router.
interface Dialer1
description "Jetstar Cert/Dev IPT Link"
bandwidth 64
ip address 172.20.248.90 255.255.255.252
ip nat outside
encapsulation ppp
no ip mroute-cache
dialer pool 1
dialer remote-name FDICHAP-D1
dialer idle-timeout 7200
dialer string 02xxxxxxx
dialer-group 1
ppp authentication chap
ppp chap hostname JETCHAP-D1
ppp chap password 7 blah
crypto map LOCALMAP
Any ideas why it timesout after 120 secs.
Cheers
Dean
7 Replies 7
j.moran
Dean I sympathize with you, I just noticed the same symptoms on my 1760 and need this resolved quickly!
awairlines
Sounds as if your interesting traffic is not specified and the line goes down because it doesn't see any interesting traffic being passed. At least this was our solution.
dbellazetin
Level 4
Level 4
Can you provide the physical interface configuration, along with the dialer list config.
Debug dialer while the problem is occuring should also explicitly tell you why the line is going down.
If the device you are dialing to has an idle timer of 120 that could be bringing down your connection.
Daniel
Physical Configuration below:
interface BRI0/0
no ip address
encapsulation ppp
dialer pool-member 1
isdn switch-type basic-net3
Feb 12 09:54:56.982: BR0/0:1 DDR: Remote name for FDICHAP-D1
.Feb 12 09:54:56.982: BR0/0:1: interface must be fifo queue, force fifo
.Feb 12 09:54:56.986: %DIALER-6-BIND: Interface BR0/0:1 bound to profile Di1
.Feb 12 09:54:57.018: BR0/0:1 DDR: dialer protocol up
.Feb 12 09:54:58.004: %LINEPROTO-5-UPDOWN: Line protocol on Interface BRI0/0:1, changed state t
o up
.Feb 12 09:55:02.651: %ISDN-6-CONNECT: Interface BRI0/0:1 is now connected to 0289239100 FDICHA
P-D1
Does the FIFO queue mean much to you.
Physical interface looks ok. Don't worry about the FIFO. What I would suggest is doing the following.
1) Enable the following debugs and then fire up the connection:
debug ppp neg
debug isdn q931
debug dialer
2) Once the connection is established wait a about 20 to 30 seconds and type in the following:
show dialer
show caller timeout
3) Do some thing to cause interesting traffic to flow across the link.
ping
file transfer
4) Do the same show commands again.
show dialer
show caller timeout
The first time you do the show commands you should see that the idle timer is counting down to zero. Once you push interesting traffic across and do the show commands a second time you should see that the timer should have reset itself. If the call still terminates after 120 seconds even though the show commands indicate that the idle timer is working properly then the debugs will tell us who is disconnecting the call.
Daniel
vcjones
Level 5
Level 5
Have you checked the timeout setting at the other end of the call? Remember that either router can terminate the call. If you don't have access to the router being dialed, turn on ISDN events debugging and look at the call termination event to see which end initiated the hangup. Post the debug if you need help interpreting it.
Good luck and good hunting!
Vincent C Jones
www.networkingunlimited.com
Thanks Vincent.
The router on the other end was set to default timeout of 120 secs and was dropping the call.
My issue is solved.
Dean Pecorari
