Cisco CNS NetFlow Collection Engine missed flows
scoe
We have a customer who uses Netflow Collection engine V3.6(1) to monitor Cisco 7200 and some Cat 6509 switches running IOS V12.1(13)E1.
Works ok for 7200 but it misses flows for the 6509s - in fact it only gets a tiny fraction of the flows and misses millions.
Any ideas anyone
agugger
How do you configure the netflow on the 6509?
The 6500 have two components a router called msfc and a layer 2 switch controlled by the msfc router. Both has to be configured to deliver netflow information. The main part will be from the switch because after a flow is initialised it passes only the switch. The router is able to deliver the router netflow formats and the switch use the slightly different formats. The switch has 3 different formats for the transport: "destination", "destination and source", "full flow" means destination, source and ports. This controls the size of the forwarding table. It should not exceed 32K entries.
Andy
joburgos
Check out www.linmor.com they have a Netflow module for their perf. monitor product , low cost solution.
