06-14-2002 12:34 AM - edited 03-01-2019 10:11 PM
Anyone knows that any of the Cisco router model can function like an ISDN lan modem, i.e. whenever there is Internet traffic demand, the router will call to ISP by ISDN and login to Internet based an username and password that given by the ISP (Just like the one that the analog modem dial-up).
The router will obtain an IP address from the ISP. Whenever there is no more Internet traffic, the router will disconnect the line in a given time frame.
Please suggest the appropriate Cisco router model and any sample configuration of it.
Please help out.
06-14-2002 01:09 AM
u can use cisco 801 router it has a bri interface & can make what u need
06-14-2002 01:15 AM
here's an example:
isdn switch-type basic-net3
interface Ethernet0
ip address xxxxx 255.255.255.0
ip nat inside
no shut
interface BRI 0
no shutdown
description connected to Internet
ip address negotiated
ip nat outside
no ip directed-broadcast
encapsulation ppp
dialer string xxxxx
dialer idle-timeout 300
dialer enable-timeout 5
dialer-group 1
dialer hold-queue 20
ppp authentication chap callin
ppp chap hostname xxxxxx
ppp chap password xxxxxxx
no cdp enable
no shut
no ppp multilink
ip nat inside source list 1 interface Bri 0 overload
no ip http server
ip classless
ip route 0.0.0.0 0.0.0.0 bri0
dialer-list 1 protocol ip permit
06-14-2002 07:44 AM
Thanks man on the 801 configuration guide.
06-17-2002 01:33 AM
Hi, first of all I tested your above configuration on a 2610 router. The symptom is that I failed to connect to ISP as the router console show that the BRI0/0 was connected to 1525 (my ISP ISDN #) and change state to up but immediately after that the bri0/0 changed state to down.
The state up and down continuously. What could be the reason ? My username and password are correct.
I used IE to enable the Internet traffic and I used ISDN Switch-type basic-net3.
06-14-2002 01:19 AM
You can do this using any cisco low end router with onr BRI and one ethernet interface. ( my choice a cisco 1600 )
i can send you the required configuration on the router , to a email address.
you can mail me at - gouthamb@hotmail.com
06-14-2002 07:43 AM
I had emailed to our email address "gouthamb@hotmail.com" to request for the configuration guide on the router 1600. Please email me the entire configuration guide to me at "fkseow@datascan.com.my".
Thank you very much.
