Collapsed Core/Distribution Q: L3 VLANs and L2 Port Channels
John-Eddie
Beginner
Beginner
Hi All,
Basic architecture of the above network is:
-Collapsed core/distro utilizing a stack of two 3650s
-Edge/workgroup switches are other brands
-Each workgroup switch represents a separate /27 ip subnet.
-Each workgroup switch supports LACP and will have two ports uplinking to the 3650s (one on each)
-The switches are already configured for LACP on the uplink ports
Here's my question:
It seems that the correct way to approach this is to leave the workgroup switches as L2 devices, and have the two ports in the port channel on the 3650 as L2 switch ports, but with a VSI assigned to a VLAN for each port channel (the default gateway the workstations get from DHCP).
Example:
(on 3650 stack)
interface Port-channel21
switchport trunk allowed vlan 21
switchport mode trunk
interface GigabitEthernet1/0/48
channel-group 21 mode active
spanning-tree portfast disable
interface GigabitEthernet2/0/48
interface Vlan21
ip address 172.31.252.129 255.255.255.224
Does this seem sane/a good idea?  Additionally, why don't the ports in the port channel show up as members of VLAN 21 when I issue "show vlan" (it's empty)?
Thanks!
John-Eddie
balaji.bandi
VIP Community Legend VIP Community Legend
How big is the setup is very important when you designing the Collapsed Core/Distribution
If the small setup you can with smaller switch, 3650 look at the End of Sale and End of Life
Collapsed Core/Distribution - always look for 5 years plan, so you do not going to touch on day to day basis and plan more resilience as services are running through your Core.
If you have DHCP Server centrally you can use DHCP help to get IP address in the VLAN Interface config.
You can L2 Port channels to Collapsed Core/Distribution from Access Switch (look at the 3rd party compatable guide)
BB
Recognize Your Peers
