compatibility of GLC-TE and GLC-SX-MMD with WS-C3850-12XS-S
khaled masri
i'm looking to connect GLC-TE and GLC-SX-MMD on same switch WS-C3850-12XS-S,
i check the compatibility matrix and show that i have to use Software Release XE 3.6.7E, XE 3.7.5E, 16.5.1a for GLC-TE
and XE 3.7.1 for GLC-SX-MMD
My question is can XE 3.7.5E support both GLC-TE and GLC-SX-MMD ????
Rich Uline
Khaled,
The minimum software release is, as it says, the minimum requirement. Higher versions of the same software will support the previous SFPs. Therefore, IOS XE 3.7.5E (and higher) supports both the GLC-SX-MMD and GLC-TE SFPs.
Rich Uline
Khaled,
thanks for your help
